Home > In Car Electronics (L322) > touch screen nav dim |
RR2008HSE Member Since: 06 Jan 2013 Location: British Columbia Posts: 2932 |
I had that problem with mine and dreaded finding out the cost of a new screen. The mechanic updated some software and that sorted the problem. |
3rd May 2013 7:24pm |
A1GSS Member Since: 24 Dec 2010 Location: Saffron Walden, Essex Posts: 1973 |
Mark_j, No. It's uselessly crap. Same system in the Disco. It is incapable of recognising nighttime (or even having a night setting). The two settings you can have are very similar, so it's not worthwhile switching except for brightness levels. I just turn mine off.
3rd May 2013 7:44pm |
Cam-Tech-Craig Member Since: 03 Aug 2011 Location: Gloucestershire Posts: 16284 |
The touch screen has a light sensor so does not dim with the light switch, as you can run in the daytime with lights on if necessary and still see the screen...
3rd May 2013 9:09pm |
