Home > Technical (L322) > rumbling front end !!!!!!!
simonmanx
Isle Of Man 2005 Range Rover Vogue SE Td6 Java Black
recently i have had a knocking on the front and have change anti roll bar links , lower ball joint and lower arm on both sides and the knocking has vanished im now left with a rumbling even at low speeds and gets worse if i turn left putting weight onto the drivers side thats the side the noise seems to come from ive swappped the tyres around finally i have replaced my 3 month old discs and pads in case the rumbling was a warped disc. it sound like warped disc or a bad tyre i even get a wobble if braking ! has anyone had this or know what a diff feesl like on the way out or wheel bearing ps i have no play on the wheel bearing that i can find !!
Post #185884 30th Apr 2013 9:54pm
Googsy
Did you do alignment/ tracking after replacing bushes ball joints etc? Present :2008 TDV8 HSE
Gone Audi A5 2.7TDI
Gone Discovery 3 HSE
Gone Mercedes CLK
Gone Range Rover 2.5 DSE
Post #185886 30th Apr 2013 9:58pm
simonmanx
i didnt do the tracking as i didnt replace steering track rod ends
Post #185887 30th Apr 2013 10:00pm
Googsy
I had these done on my car recently it's imperative you have tracking/ alignment done when any of these components are replaced or suspension and wheels will be out of alignment . I would say this is why you are experiencing the vibration / rumble. I can't see it being a wheel bearing as noise has only appeared since components have been replaced. I would bet its an alignment issue not costly about 50 quid. Present :2008 TDV8 HSE
Gone Audi A5 2.7TDI
Gone Mercedes CLK
Post #185888 30th Apr 2013 10:03pm
wslr
United Kingdom 2010 Range Rover Vogue SE TDV8 Atacama Sand
Wheel bearing?
Post #185889 30th Apr 2013 10:09pm
simonmanx
or diff not sure yet Big Cry
Post #188343 14th May 2013 8:53pm
