Home > Maintenance & Mods (L322) > Rear brake dust plates |
Discotigger Member Since: 12 Feb 2013 Location: Cumbria Posts: 804 |
The hubs have to be removed to replace the plates and it can be a pig of a job to do the hubs if they haven't been removed/replaced before. When I did my front dust plate (also known as splash guards) the easiest way was to cut the new guard at the narrowest section, bend it to get it into position, then reweld the metal and apply a bit of paint prior to bolting it in place. Then you don't have the hassle of removing and replacing the hub assembly.
29th Apr 2013 6:37am |
Cam-Tech-Craig Member Since: 03 Aug 2011 Location: Gloucestershire Posts: 16294 |
As above really but to add, In removing your rear hubs, you will probably knacker up your wheel bearings etc by not using Land Rover hub pusher/puller tools... Large expense for a few washers... |
29th Apr 2013 6:56am |
RRBlue Member Since: 23 Feb 2012 Location: Cambs Posts: 222 |
Can I get away with just removing the drive flange that holds the wheel studs? |
29th Apr 2013 7:10am |
Unfortunately the whole assembly has to come off and as stated it's a pig of a job. Plus the time and costs involved to disassemble and reassemble the assembly doesn't really warrant the £25 odd cost of the guard.
29th Apr 2013 11:26am |
nicedayforit Member Since: 11 Jun 2011 Location: Beside the Solway Posts: 3977 |
This is the rear backing plate.
29th Apr 2013 11:46am |
Agree. That is hat I shall do. Many thanks. |
29th Apr 2013 1:12pm |
