![]() | Home > Technical (L322) > Calling RRPhil |
RRPhil Member Since: 22 Aug 2011 Location: Blackburn, Lancashire Posts: 1001 ![]() ![]() |
If you do decide to order a new intermediate plate then it might be worth mentioning that you should really also replace the bridge seal
and the four jump tubes
when the Mechatronic unit is removed. These parts are relatively cheap and are available from Land Rover
Bridge seal = TGW 500010 Small jump tube = TZT 500010 (2-off) Medium jump tube = TZT 500020 Large jump tube = TZT 500030 As yours is an early model, it may also be worthwhile upgrading the multiplug connector sleeve (which is prone to leak)
to the latest version (TZV 500010) Phil Admin note: this post has had its images recovered from a money grabbing photo hosting site and reinstated ![]() |
While waiting for price and delivery time of the mechatronic parts, I have updated the Engine ECU software as well today. Now I know what to look for it went quite quickly. Engine runs a bit smoother and I didn't have the CEL on at the end of the drive (short drive though).
Phil, I am talking to an automatic gearbox outfit in the Netherlands as the dealer can't supply all the parts (especially the delay piston and shift valve damper as well as the sheet). They are of course trying to sell me a lot more as they don't sell those parts loose (they say they will take them from an old Mechatronic).
Your Lucky Eb,
But you can get Pete Bell performance flash files loaded |
TheAllSeeingPie Member Since: 18 Apr 2012 Location: Leeds Posts: 848 ![]() ![]() ![]() |
Does anyone know if Pete Bell does gearbox upgrades for the SC?
As far as I understand he only does upgrades to diesel engine management. MY 2010 5.0 SC Galway green and sand interior!!
Using the MSV2?? I saw about the PB maps so thought he must offer discount on them as well.
The ecotune has nothing to do with PB as far as I know.
Where do the ecotune ones come from?? FFRR MY06 facelift With TDV8 Alloys Zeros/ATR's
No clue. MY 2010 5.0 SC Galway green and sand interior!!
BBS post here i come! Though i tend to feel its a tumbleweed area their forum |
The catalogue of the supplier that I use here in the UK (http://www.jpat.co.uk/6HP26.pdf) lists the seals and the intermediate sheet but not the individual valves. It was certainly ZF�s original intention to only supply the valve blocks as complete assemblies though these policies sometimes change as the product gets older. Should I contact JPAT on your behalf and make some enquiries? I could get a quote for the seals/plate at the same time. If we draw a blank on the individual valves I could always send you mine to try.
So just to recap - The 3-4 shift is achieved through the engagement of the E-clutch while the B-clutch is released. The E-clutch then stays engaged in 5th and 6th gears too so the fact that the transmission seems to perform okay in these higher gears seems to indicate that there isn�t an issue (either mechanical or hydraulic) with the E-clutch itself. So the problem seems to relate to the actual period of engagement of the E-clutch and the delay accumulator valve is there to act as a damper volume to modulate the pressure rise specifically during this engagement period. It seems sensible therefore to examine this component carefully to check the spring and the free movement of the piston in its bore. Other primary components involved in the 3-4 shift are Shift Valve I and the on-off MV1 solenoid (with the black cap). These should also be visually checked and preferably have their performance verified by substitution.
Hi Phil,
Many many moons ago, my dad had a problem with his Triumph 2500TC gearbox, a Borg Warner if I remember correctly. Now this was the best maintained Triumph in the world without a doubt. His box developed an issue and he decided to dive into it himself. The part that caused the issue was a tiny metal plate bent in a 90 deg angle that had developed a little burr that made it stick where it shouldn't. It cost him the equivalent of 1 GBP at the time. Problem solved and many happy miles followed after that. I'm hoping for something similar of course !!!! MY 2010 5.0 SC Galway green and sand interior!! Have the Faultmate MSV2 Extreme to be tinkering with the settings etc. !! |
