Home > In Car Electronics (L322) > Where should I slip my tool?
Flashman
England 2011 Range Rover Autobiography TDV8 Santorini Black
I am changing the connectors on my headlights and PDC loom for a conversion and want to remove the wire plugs from the connectors. I have attached the two pics, one of the new headlight plug and the other from a 2010 PDC loom.
Can anyone advise where I stick the tool in order to release the connector. My guess is the red arrow, but I want to make sure before I bu**er it up! Martin recommended using a paper clip, but I am not sure it will be strong enough to unclip them.
Any help is appreciated, as I don't want to bend my tool, snap it off or indeed break the connectors whilst trying to get an easy and quick release. Tom
Current Drive
2011 4.4 TDV8 Autobiography - Santorini Black - Ivory Leather
Previous Drives
2004 Model Vogue Td6 (Touchscreen) - Java Black - Parchment Leather
1994 RR Classic 3.9 V8 Soft dash - Niagara Grey - Grey Leather
1972 Series III SWB Safari - Green (Hand Painted) - Black Plastic
Post #184702 25th Apr 2013 2:45pm
Bushy513
United Kingdom 2003 Range Rover Vogue Td6 Monte Carlo Blue
This post is doomed I feel to a large amount of innuendo with a title like this Laughing
Good luck with the conversion. Bushy
2003 RR Vogue Monté Carlo Blue
Post #184717 25th Apr 2013 4:04pm
crookedm
2007 Range Rover Vogue SE TDV8 Java Black
Yes, I'm sure someone will give you one. Rolling with laughter
Post #184788 25th Apr 2013 10:26pm
On both connectors I would have thought that the inner part should release somehow and come out forwards, exposing the back of the connections? Access to the back of the connectors should provide obvious release of individual pins? Don't have experience of this, just a suggestion.... .
Post #184797 25th Apr 2013 11:23pm
Flashman
From what I can see I need to push a lever down to release the clip, I have tried using a paperclip but it does nothing and just bends. I might pop into Maplins to see what they have. Tom
Current Drive
Previous Drives
Post #184828 26th Apr 2013 8:23am
Perhaps a spectacles screwdriver set (that's what I call them) has the length, strength and skinniness needed .
Post #184829 26th Apr 2013 8:25am
Flashman
I've tried A&F screwdrivers (watch repairs etc) and they are not long enough and I am worried they will snap, hence wondering if there is a special tool to make it easier. Tom
Current Drive
Previous Drives
Post #185063 27th Apr 2013 10:01am
You need a 4-6" pick then go in where the red arrow is, touching the metal with the point and push to the rear, then lift the plastic flap whilst pulling the wire... Simples Rolling Eyes Shocked Thumbs Up
Post #185066 27th Apr 2013 10:16am
Flashman
Nice one Craig! Tom
Current Drive
Previous Drives
Post #185147 27th Apr 2013 6:50pm
