Home > Technical (L322) > Parking Sensors |
If a single sensor fails, the whole system won't work. Makes sense of course but is also annoying
20th Apr 2013 4:35pm |
kiter Member Since: 04 Jan 2013 Location: Inverness Posts: 182 |
Cheers - hopefully will fix it - there was a receipt for a new control unit in the file I got with the car and its only about 8 months ago so hopefully this is an easy fix. |
20th Apr 2013 4:40pm |
Bushy513 Member Since: 25 Feb 2013 Location: Colchester Posts: 392 |
Are they not working at all? Or do you get a continuos tone? Bushy
20th Apr 2013 6:56pm |
yep - get a continuous tone and light flashing at the dash switch when I go into reverse. |
20th Apr 2013 7:20pm |
Well with the new module already fitted, I would guess the sensors are the most likely culprit, however if you replace them and still get this continuous tone, like me , try replacing the rear parking sensor loom located in the bumper. This is a apparent very common fault that our cars suffer with. The wires corrode as they contact the sensor and over time they fail completely. Bushy
20th Apr 2013 7:26pm |
cheers for that - will give the sensors a try first and see where it takes me - had hoped to do the digi Tv upgrade but can see that having to wait another month at this rate.......... |
20th Apr 2013 7:32pm |
I replaced two sensors (the Faultmate told me which ones failed) and it was fine after that MY 2010 5.0 SC Galway green and sand interior!!
20th Apr 2013 10:03pm |
