![]() | Home > Maintenance & Mods (L322) > Bike Rack for ball type tow hitch |
verydisco Member Since: 10 Dec 2009 Location: UK/US Posts: 2952 ![]() ![]() ![]() |
Hi gang.
Joe90 Member Since: 29 Apr 2010 Location: Hampshire Posts: 6419 ![]() ![]() |
You should be able to find a replacement "normal" towbar fitting on eBay, then you can use whatever you want for a bike rack. The square end is a standard size. Search for motorhomes or similar. .
stan Site Moderator Member Since: 13 Jul 2010 Location: a moderate moderated moderator moderating moderately in moderation Posts: 35628 ![]() ![]() |
its 2 inches square btw.. ... - .- -.
Alistair Member Since: 11 Feb 2011 Location: Peterborough / Bordeaux / Andorra Posts: 8000 ![]() ![]() ![]() |
There are loads that will clamp onto a swan neck tow ball - Thule & plenty of others.
No it isn't ![]() "US Type" is probably the best description as it's actually 50mm square. I have a Jeep with a 2" square receiver and several inserts, all of which are slightly too big for the FFRR. 2" = 52mm ![]() |
northernmonkeyjones Member Since: 24 Mar 2012 Location: derby Posts: 8749 ![]() ![]() ![]() |
http://www.pfjones.co.uk/westfalia-portilo...rrier.html
TheAllSeeingPie Member Since: 18 Apr 2012 Location: Leeds Posts: 848 ![]() ![]() ![]() |
Alistair, can't you just angle grind it down a bit?
Thanks lads, however, the all of them do not allow to drop the tailgate unfortunately.
This is what I need:
Not tried that one - one of my mates has a very similar Thule one - very heavy once the bikes are on it - dropping & raising is not a one person job.....
DavidP Member Since: 20 Oct 2010 Location: BN Posts: 425 ![]() ![]() ![]() |
verydisco.
Hmmm, mine was a bit tight (I bought one for an "RV" as opposed to a "motorhome" from a UK eBayer) (currently measures as 50mm though), but I just sanded down the powder coating a bit to make it fit ![]() ![]() Experience is the only genuine knowledge, but as time passes, I have forgotten more than I can remember ![]() Volvo V70 P2 2006 2.4 Petrol 170bhp Estate SE MG Midget Mk1 1962 Previous: L322 Range Rover TDV8 3.6 2008; L322 Range Rover TD6 3.0 2002; P38A Range Rover V8 1999 |
