Home > General > Rusty Rangie
Roystonh
Rusty Rangie
Hello all
I have got a 2011 Vogue and have recently found some rusty bits. The paint has gone lumpy showing rust on the top of the rear door (just above window) and the rubber around the rear window has gone lumpy at the top and n bottom on both sides (where the glass is held in).
I'm taking it in tomorrow for a warranty inspection, but has this been suffered by other owners?
Thanks Roy 2005 L322 Vogue Gold gone
2006 L322 Vogue Black gone
2011 L322 Vogue Silver gone
2011 L322 Autobiography Black gone
2015 L405 Autobiography LWB Black gone
2019 L405 P400e Range Rover Autobiography LWB Eiger grey / black roof gone
2001 P38a 30th Anniversary Wimbledon Green gone
2019 L405 P525 Autobiography LWB British Racing Green
Post #183467 17th Apr 2013 9:34pm
A1GSS
They all do that sir. Part of the service. Graham
____
Gone: 10MY L320 RR Sport HSE, Ipanema Sand
Gone: 20MY Jaguar iPace HSE, Silicon Silver
Gone: 17MY RR Evoque SE Tech, Loire Blue
Gone: 08MY Discovery 3 XS, Stornoway Grey
Gone: 07MY FFRR TDV8 Vogue, Stornoway Grey
Post #183475 17th Apr 2013 10:33pm
A1GSS
You could try complaining. I did, and got nowhere. What a load of crap. Corrosion on a nearly new modern car. Graham
____
Post #183476 17th Apr 2013 10:33pm
rjbax1978
2011 Range Rover Vogue SE TDV8 Galway Green
I had the same problem with the rear window surround and they are going to replace under warranty 2011 TDV8 Galway Green Vogue Se
With RSE and Deployable steps
Post #183555 18th Apr 2013 2:04pm
barrieeld
I had this on my car and although the dealer tried I got no place as my car was over 3 yrs old.
I told them i didnt give a Censored the car was a 3.5yr or (£85k when new) car thats rusting and my partners fiat 500 was in better condition....the result?....nothing. Range Rover SC 35th Anniversary 2006
Post #183556 18th Apr 2013 2:10pm
Mr Tee
the rubber trim strips at the bottm of the window are a relatively cheap fix,most i've seen are the same.
Post #183558 18th Apr 2013 2:17pm
The rubber window trims are aluminium inside - its not rust but some form or alloy corrosion. Very common on older cars so just buy new ones.
Post #183568 18th Apr 2013 3:06pm
ebajema
Sounds like galvanic corrosion where two dissimilar metals (of which one is less noble) start to react basically create a battery when an electrolyte is added (water, preferably slightly salty). The less noble metal will then start to corrode as it loses electrons.
You see it on boats where they attached zinc/aluminium anodes to protect the steel hull from corrosion (also offshore platforms and pipelines, the business I am in).
If the coating on the metal is intact, the electrolyte can't get to the metals and things are fine but over time the coating wears, gets damaged (could also be at initial installation or just bad paint job) and the corrosion starts.
Bottomline is, get it cleaned up, coated properly (repainted and then some waxoil) and put the rubber strips back in. You should be fine for years then. MY 2010 5.0 SC Galway green and sand interior!!
Post #183571 18th Apr 2013 3:14pm
Post #183573 18th Apr 2013 3:21pm
Brewster
England 2006 Range Rover Vogue SE TDV8 Buckingham Blue
When I bought mine I noticed a couple of rust bubbles under the paint. I thought they had a 6 years corrosion warranty so went to my local dealer who took some pictures. Came back with the response that because there wasn't a hole in it it was a non starter. I pointed out that in the warranty book it didn't state this and it repeatedly mentions corrosion warranty not perforation warranty ie if it has corrosion before the expiry of the warranty it was covered...apparently NOT!!
Mine had a full corrosion inspection stamp list too. One thing to mention is that even if you have your car serviced elsewhere than a main dealer go and get the corrosion check done at the main dealer otherwise he was saying you ain't got a leg to stand on !!!
I agree with others that this is really poor. Talking to my local approved body shop this is pretty common for them to show signs of corrosion both on the aluminium parts bonnet etc. and the galvanised steel parts too. He mentioned to check the tailgate for corrosion on the lower edge and to ensure the drain holes are clear as the water can build up in the top tailgate and rot it from inside out ....and you don't even want to know the price of a replacement!! ...Always time for a brew !!
2006 TDV8 Vogue SE
Post #185356 28th Apr 2013 8:44pm
