Home > Maintenance & Mods (L322) > Seal Leaking Coolent Pipe |
Budgie Member Since: 09 Jul 2012 Location: Stornoway Posts: 267 |
I put a new water pump on my 2003 4.4 FF last week and I was doing an inspection today to make sure all was well and to tighten up the belts I replaced and I've found a small coolant leak from one of the push-on pipe connectors.
10th Apr 2013 6:13pm |
Rob2529 Member Since: 22 Nov 2010 Location: Wirral, uk Posts: 1470 |
If you can check you haven't list the o ring inside. They should be a snug fit even with retaining clip removed. I used a bit of Vaseline type stuff to help pub and seal mine when I was removing and replacing. The clip just stops it popping off under pressure. [img]http://www.fuelly.com/driver/rob2529/range-rover[img/]
10th Apr 2013 7:50pm |
Nice one Rob, I didn't realise there was an o-ring in there. That's maybe gone so I'll drain the system down again and check as I've got a box of o-rings in the garage. |
11th Apr 2013 12:01am |
I wouldn't drain it down. Get a hose clamp and a bung for the rad. Should give you enough time to look for the o ring and save having to re-bleed the system as its a ballache! [img]http://www.fuelly.com/driver/rob2529/range-rover[img/]
11th Apr 2013 12:59am |
