Home > Maintenance & Mods (L322) > door mirror
reynolds
England 2004 Range Rover Autobiography Td6 Buckingham Blue
door mirror
please could any body tell me how to remove the rear of the door mirrors as i want to check the bulbs under them as neither of them seem to work cheers Sad Sad
Post #18212 14th May 2010 7:20am
stevegt
United Kingdom 2006 Range Rover Autobiography 4.4 V8 Cairns Blue
Just pop the mirror glass off and poke a screwdriver down the slot next to the light bulb symbol and the puddle light will pop out from underneath the mirror housing.
Steve 06MY 4.4 V8 Autobiography Cairns Blue with Navy & Parchment Interior
Post #18224 14th May 2010 1:12pm
reynolds
cheers does the mirror glass just pop of
Post #18226 14th May 2010 2:17pm
stevegt
yes it does, it requires a reasonable amount of force. It is a thick unit so don't be too afraid... having said that as with all Range Rover parts they are expensive. 06MY 4.4 V8 Autobiography Cairns Blue with Navy & Parchment Interior
Post #18228 14th May 2010 2:24pm
Do what I did, drive the car so close to a hedge it bangs the mirror glass out so its dangling on its wires Shocked Discovery 4 HSE
Post #18236 14th May 2010 3:19pm
daveo
while they are off upgrade them bulbs to the led ones, the ends of the led bulds must be under 12mm to fit through the bulb holder.. they make a big difference...
daveo
ps, check to make sure no idiot has sprayed over the lens, my ones had by the person who painted the back covers V8 facelift Range Rover Autobiography 22" wheels.
Post #18240 14th May 2010 4:13pm
doublejay
we're talking about the puddle lighting ? i have one gone too.... would be interested if anyone fits a LED. It does look kind of flash when you lock to the car.
Post #18366 17th May 2010 11:56am
hoppy_70
England 2018 Range Rover Autobiography 2.0 PHEV Loire Blue
Anyone know how to remove the 2007 ones? Theyre a different lens, does that just pop off??
Post #21773 7th Jul 2010 5:39pm
Duke Thrust
United Kingdom 2007 Range Rover Supercharged 4.2 SC V8 Java Black
I need to replace one of mine too, I need to pluck up courage to prize the mirror off!!
Post #22950 22nd Jul 2010 10:02am
hoppy_70
You don't have too! You can poke a screwdriver under the mirror glass and release the clip. Towards the outside edge of the mirror there is an access hole, if you poke a small screwdriver into that and lever, it will release the oust clip that allows the lamp to drop down.
Once you've done it, you'll be able to do it each time. If you do have to pop off the mirror glass then pull it from the bottom. When putting it back it goes on at the top 1st before snapping back in at the bottom.
Good luck.
Ps. I tried LEDs in the mirrors but couldn't get them to work form some reason.... My Previous RR's!
2018 P400e Autobiography
2008 TDV8 Vogue
2006 TD6 Vogue
2007 TDV8 Vogue
2007 RRS (I know, it doesn't count!)
2005 4.4 Vogue on LPG
2005 TD6 Vogue
2003 4.4 Vogue
2001 4.6 HSE
2000 2.5 DHSE
1999 4.6 HSE
1997 4.6 HSE on LPG
1995 2.5 DSE
1989 3.9 EFI classic
1988 3.5 EFI classic
Post #22999 22nd Jul 2010 7:55pm
