Home > Wheels & Tyres > Tyre size question
Rich86
United Kingdom 2009 Range Rover Vogue TDV8 Nara Bronze
Tyre size question
I've got 255 50's on my 20" wheels but have been offered 245 45's at a decent price.
If I fitter slightly narrower tyres would they:
A) fit the wheels ok
B) make any noticeable difference to road holding or performance?
Obviously wider tyres are a bit more stable but is the difference that critical?
Post #182048 9th Apr 2013 6:30pm
BrianC
They will make the wheels look like they don't fill the arches
Post #182061 9th Apr 2013 7:40pm
Rich86
Hmm not that great then?
Post #182062 9th Apr 2013 7:45pm
BrianC
The ones I'm selling are the ones to go for �but you would be 3rd in the queue at the moment Thumbs Up
Post #182065 9th Apr 2013 7:51pm
Rich86
Lol you crafty old devil. Won't the 45 s improve the economy of the car?
Post #182071 9th Apr 2013 8:14pm
BrianC
Not sure �I'm sure someone on here has pictures with sport wheels on there ffrr it looks wrong IMHO
Each to there own Thumbs Up
Post #182072 9th Apr 2013 8:15pm
About 30mm difference in sidewall height. There is nothing that can't be fixed with a hammer😜😜
Post #182080 9th Apr 2013 8:33pm
Rich86
So would that make the car slightly lower?
Post #182081 9th Apr 2013 8:39pm
Would probably also invalidate your insurance, unless you told them, in which case it would most likely increase your premium......
Post #182083 9th Apr 2013 8:41pm
comports
United Kingdom 2016 Range Rover Autobiography SDV8 Mariana Black
And possibly give you a harder ride with less tyre wall to run on and "soak up" some of the bumps Ash
2022 SDV8 AB
2016 TDV8 VSE
2011 TDV8 VSE
2006 V8 Vogue
2002 2.5 Vogue
Post #182086 9th Apr 2013 8:46pm
I have winter tyres 235/65 R18 and normal tyres 255/55 R19. I notice naff all difference in ride/handling/mpg.
They're both big tall squashy tyres so it's hard to tell much difference.
My sports car with different tyre widths made a huge difference to ride/handling/mpg.
Maybe those with 20's or bigger wheels will notice a bigger difference but on 18's and 19's it's hard to tell.
Post #182099 9th Apr 2013 9:03pm
Would make the wheels look like they dont fill the arches properly. Wheel would be 2" smaller overall. You are not only reducing the aspect ratio (50-45) but also the width 255-245 so double whammy. There is nothing that can't be fixed with a hammer😜😜
Post #182100 9th Apr 2013 9:03pm
Rich86
I'm thinking maybe not great then.
Can believe no one has fitted these to their FF...
Post #182104 9th Apr 2013 9:07pm
Randv
Switzerland
Standard tyre size: 255/55 R 19
Total wheel diameter (mm / in): 763 / 30
Percentage diameter difference to the original (%): 0
Standard tyre size: 255/50 R 20
Suggested tyre size: 245/45 R 20
Total wheel diameter (mm / in): 729 / 29
Percentage diameter difference to the original (%): -4.5%
That�s 4.5% smaller rolling diameter, and that�s a lot!
Post #182336 11th Apr 2013 7:50am
Rich86
Rand that's great.
Thanks for the info.
Post #182349 11th Apr 2013 8:47am
