![]() | Home > Maintenance & Mods (L322) > Severe brake judder after disc skim.... |
dont think i would have gone through that, i would of taken the disc back, did you talk to the the supplier about them V8 facelift Range Rover Autobiography 22" wheels.
Aspin83 Member Since: 22 Apr 2013 Location: Blackpool Posts: 18 ![]() ![]() ![]() |
Hi sorry to hear about your unfortunate problem with your car ? couple of questions if I may in reference to the work carried out by your garage ?
Contraband Member Since: 08 Nov 2010 Location: FIFE Posts: 3697 ![]() ![]() |
Just buy new discs... You know it needs done.
the problem is if there is a run out from the hub its self, slight wheel bearing play the symptom's will come back again in a small amount of time and mileage ? there is a minimum thickness a disc can be for obvious reasons therefore from my experience of 12 yrs and 2 with the brake machine I would skim the disc's even if you put new ones on and trued them up to the hub too ? |
