Home > Technical (L322) > Dash top removal 2008
Googsy
Watched a Powerful UK video on how to remove top of dash it was a preface lift car. Is the procedure the same for facelift as there is additional vents etc? thanks. Need to replace my cracked speedo glass . Thumbs Up Present :2008 TDV8 HSE
Gone Audi A5 2.7TDI
Gone Discovery 3 HSE
Gone Mercedes CLK
Gone Range Rover 2.5 DSE
Post #181740 7th Apr 2013 7:13pm
verydisco
It is a bit more tricky, but not hard.
Take vents off, 3 bolds IIRC
Take centre speaker grill off: then the 2 screws it hid
Open upper glove box (well the CD and Venture cam box), take 4 bolds off.
IIRC there are even 2 oe 3 bolts to take off from the lower glove box
Take all the dashboard top screws off (watch out this windscreen when unscrewing)
Pull the dashboard towards you
Unbolt remaining bolts to get your binnacle out, 4 screws I think
Unplug the cables (they are rocker type plugs, easy enough)
Then do what you need to do to replace your plastic screen.
Refitting it the exact opposite
Make sure you mark the screw as some look the same but have different lengths
Cheers l=Oo\________/oO=l l:OolΞΞΞΞΞΞΞloO:l
Current
Previous:
Post #181744 7th Apr 2013 7:54pm
Googsy
Thanks Thumbs Up Present :2008 TDV8 HSE
Gone Audi A5 2.7TDI
Gone Mercedes CLK
Post #181746 7th Apr 2013 8:00pm
