Home > In Car Electronics (L322) > Parking sensor conundrum
Bushy513
United Kingdom 2003 Range Rover Vogue Td6 Monte Carlo Blue
Hi guys,
I hope someone can help with this rather strange problem I'm encountering. Sometimes I place my vehicle into reverse and the parking aid comes on as it should and works perfectly. But increasingly more common, I place it into reverse and I get a constant warning beep, as if there is a fault on the system. I took it to the main stealer a little while ago, and they assured me it was water ingress between the sensors ( quite common he said) but its been doing this after three, four, five days of no rain. If it was just a constant fault, I think it would be less annoying Censored , but the fact it's a 50/50 if it will do it is very strange.
Any ideas?
Bushy. Bushy
2003 RR Vogue Monté Carlo Blue
Post #181509 6th Apr 2013 9:09am
PaulB
2017 Range Rover Autobiography SDV8 Loire Blue
I had this problem.
I changed the parking module in the boot.
Solved it for me Thumbs Up
Post #181511 6th Apr 2013 9:29am
Budgie
Mine also does this occasionally, as well as beeping when there's nothing behind or in front of me.
I put it down to corrosion on the sensors as the paint has come off and there is what looks like alloy corrosion on there.
Something I'll get around too in the future, mostly I just ignor them at the moment.
Post #181513 6th Apr 2013 9:55am
Flashman
England 2011 Range Rover Autobiography TDV8 Santorini Black
It is very common and my rear sensors do it all the time, sometimes working and other times continuous beep for no reason. It is probably the pdc connections or a break in the wiring, but I need to remove the bumper to get to it all. I will wait for summer. Tom
Current Drive
2011 4.4 TDV8 Autobiography - Santorini Black - Ivory Leather
Previous Drives
2004 Model Vogue Td6 (Touchscreen) - Java Black - Parchment Leather
1994 RR Classic 3.9 V8 Soft dash - Niagara Grey - Grey Leather
1972 Series III SWB Safari - Green (Hand Painted) - Black Plastic
Post #181516 6th Apr 2013 10:27am
broncoupe
Seen this many times like the other guys say corrosion of the bumper wiring loom.
UK dealers only charge £20.00 for this item that tells the whole story when have LR been so reasonable.
The actual cable corrodes from the inside out I think the insulation fails.
Broncoupe
Post #181532 6th Apr 2013 12:07pm
Dolphinboy
+1
dodgy/broken wiring. Normally happens a coupla cm from the plug in to the sensor itself, where it has to bend.
Post #181547 6th Apr 2013 3:23pm
If you put your ign on then select parking sensors, get out and put your ear next to each sensor and the working ones will tick quickly... I would start with tracing the wiring from the duff one/ones...
Craig Thumbs Up
Post #181599 6th Apr 2013 11:54pm
Bushy513
Wow,
Ok I'm getting a reoccurring theme here. I'll check today thanks for all of your help guys. Razz Bushy
Post #181605 7th Apr 2013 5:46am
