Home > Technical (L322) > Normal run temp
spanner
Normal run temp
I put my OBD program on today whilst running and after around an hour the coolant temp was only 53c this seems low and my gauge was just above the blue and when i think it never goes any further could this be thermostat (heater temp fine)
Post #181489 5th Apr 2013 7:05pm
Too cold, cant remember what it should be but around 90 ish i think.
Sounds like a stat stuck open.
Which engine do you have? There is nothing that can't be fixed with a hammer😜😜
Post #181494 5th Apr 2013 9:59pm
TheAllSeeingPie
United Kingdom 2007 Range Rover Supercharged Supercharged Java Black
I've been monitoring stuff like this for a while. Mine generally runs at 96 for coolant and engine oil.
07 Supercharged - Still breaking her in!
Boot soundproofing part 1 - http://www.fullfatrr.com/forum/topic15612.html
Custom exhaust - http://www.fullfatrr.com/forum/topic15296.html
18" wheels for Brembo equipped cars - http://www.fullfatrr.com/forum/topic15052.html
Post #181499 6th Apr 2013 8:18am
666tur
United Kingdom 2012 Range Rover Vogue SE TDV8 Zambezi Silver
Normal running temp is c. 90 degrees. I recently had the same issue, changed the main stat and egr stat to fix it.
I was struggling to get the cabin warm on very cold days. 2012 4.4TDV8 VSE
2004 TD6 132k miles- SOLD
1995 Land Rover Defender 110 Tithonus Ex Military
1995 Land Rover Discovery 3.9i V8 manual
Post #182935 14th Apr 2013 8:22pm
ebajema
It depends if you have been driving or sitting still in the driveway for an hour. Diesel engines don't warm up very well when the car is not driving (as diesels, don't know about the TD6/TDV8 though, have a coolant flow that is going "around" the thermostat). MY 2010 5.0 SC Galway green and sand interior!!
Post #182984 15th Apr 2013 8:31am
