Home > In Car Electronics (L322) > TV tuner lost its channels!
MarkBrand
United Kingdom 2005 Range Rover Vogue Td6 Java Black
I am stuck on this one! I have a TV tuner that can't pick up any channels, both antenna plugs are installed and the fan is going round in the tuner box so there power, another problem is that you can't can't change country or format options, I don't know...might be related! I bought the tuner in oct and its hasn't worked since before crimbo! Any ideas would be appreciated as I can't get hold of the guy that sold me it!
Post #181035 3rd Apr 2013 11:27am
Sorry if this is obvious, but it is a digital tuner you have I take it? Previously..
Post #181039 3rd Apr 2013 12:06pm
MarkBrand
Yea it's a hybrid dig. Tuner! It did work for a few days!
Post #181041 3rd Apr 2013 12:18pm
NormanP
United Kingdom 2014 Range Rover Vogue TDV6 Aintree Green
http://www.digitaluk.co.uk/when_do_i_switch
says: “There are 3 transmitter groups in Northern Ireland that will switch from analogue to digital TV from 10 October 2012. When you switch depends on which transmitter group you are watching. More detailed information about these transmitter groups will be available soon.” Predictably, the site hasn’t been updated….there is a postcode checker on that site, it may be worth putting in your details and see what it says.
If you have an analogue TV receiver and are in the area affected, it won’t work without an add-on decoder.
Edited: posted before I saw your response above. Norman
Current LR: L405 Vogue TDV6 (MY 2014) Aintree Green/ Ivory interior
Past LR: L322 Vogue 4.4 V8 (2002); Discovery series1 V8 (1995)
Post #181042 3rd Apr 2013 12:19pm
have you checked the connections?
it does sound like a faulty tuner...it might be worth putting the analogue one in [if you still have it] and test the system... ... - .- -.
Post #181050 3rd Apr 2013 12:54pm
MarkBrand
Yes I have checked them a few times, all seams well, the analogue tuner went on eBay!
Post #181056 3rd Apr 2013 1:06pm
Baris
Sounds about right. These £400 -£500 tuners are failing more and more. That's why its better to a digital conversion done on the analogue tuner.
Post #181156 4th Apr 2013 6:49am
But you can't do that with the MOST system ones baris Sad FFRR MY06 facelift With TDV8 Alloys Zeros/ATR's
Post #181187 4th Apr 2013 9:15am
MarkBrand
I take it this has happened to more than one, can it be fixed? I sent you an unrelated pm Blaris.
Post #181195 4th Apr 2013 9:44am
Baris
It's very confusing on this forum, as both generations of range rovers are in the same sections. I'm assuming the MOST system your referring to is the entertainment system in the touch screen system? Which I don't know much about tbh.
I have about 3 hybrid tuners, with 3 different faults.
Post #181197 4th Apr 2013 9:54am
MarkBrand
Yes, it's a touchscreen version, any luck on the Bluetooth issue mentioned in my pm or is that not your department?
Post #181198 4th Apr 2013 10:01am
martin g
2010 Range Rover SE TDV8 Santorini Black
had this with my tdv8 try pressing auto then your stations should retune
Post #181432 5th Apr 2013 1:22pm
MarkBrand
Are there any forum members that offer a fixing service? It won't find any channels and it won't let me change country or format options, have checked all connections and ariels and all is well in that department. I only got to watch tv once since I bought it which is annoying. Sad
Post #182649 12th Apr 2013 11:31pm
MarkBrand
Just bumping this up again, as I need to get it fixed or replace it, Had no response from the guy I bought it off! Lesson learnt! 👎
Post #200495 24th Jul 2013 11:27am
does increasingly sound like a dodgy tuner...you might have to bite the bullet and get another one if you cant find a repairer. ... - .- -.
Post #200498 24th Jul 2013 11:29am
