Home > General > behind the badge
behind the badge
any one know what the little aerial behind the front 'landrover' badge is for..
Post #23872 1st Aug 2010 11:35am
I think you must mean the external temperature sensor behind the front grill . 2008 MY Supercharged
Post #23880 1st Aug 2010 1:27pm
no, its an aerial directly behind the landrover badge..
Post #23881 1st Aug 2010 1:31pm
Yep that's it it just look like an arial. 2008 MY Supercharged
Post #23882 1st Aug 2010 1:36pm
darrenmax
Belgium 2003 Range Rover Vogue Td6 Giverny Green
is this it ?
http://www.realoem.com/bmw/showparts.do?mo...mp;lang=en 2002 td6 vogue, 06 supercharged facelift
Post #23883 1st Aug 2010 1:42pm
looks like it, so it is a temp sensor..thanks axle/darrenmax
Post #23884 1st Aug 2010 1:44pm
FrankRizzo
Germany 2012 Range Rover Vogue 4.4 V8 Santorini Black
Can anyone tell me if all L322s have this sensor, regardless of age?
I'm looking to buy a new grille for my '08 L322 so I asked the seller if it had the mount for the sensor on the rear side and he said only models up to '06 have it. I need to check mine but I'm pretty sure they all have one??? 2012 Vogue 4.4 TDV8 automatic (LHD), Santorini Black
2008 Vogue 3.6 TDV8 automatic (LHD), Java Black
Post #181141 3rd Apr 2013 11:47pm
dave699
England 2007 Range Rover Vogue SE TDV8 Stornoway Grey
My 2007 has it Thumbs Up
Had it, loved it!
2007 Vogue SE TDV8
Stornoway Grey / Ivory
Climatic Seats, RSE, AFS, Deployable steps, iPod kit.
Post #181146 4th Apr 2013 6:47am
sounds like it 'might' not be a genuine range rover grill. ... - .- -.
Post #181163 4th Apr 2013 8:29am
"little aerial" Rolling with laughter Rolling with laughter Rolling with laughter
Post #181174 4th Apr 2013 9:08am
My 06-09 grille has the mount and its an SC grille and the old slatted one had it as well as fitted to most TD6/TDV8/4.4's Smile FFRR MY06 facelift With TDV8 Alloys Zeros/ATR's
Post #181183 4th Apr 2013 10:07am
Never had it on my 05 SC , also didnt have it on the amount of Grilles i have changed since , not even on my Mdl 10 one
Post #181214 4th Apr 2013 1:08pm
FrankRizzo
I don't think it is a genuine part. This is the item I was looking at:
http://www.ebay.co.uk/itm/RANGE-ROVER-L322...0672858856
Checked my current grille (see profile pic) and it has the mount but the sensor is missing!
I asked my local LR dealer to fix it somewhere because it was hanging loose when I collected it from the dealer I bought it from. Question now is, where did they fix it...? Wink 2012 Vogue 4.4 TDV8 automatic (LHD), Santorini Black
Post #181327 4th Apr 2013 8:39pm
Its not genuine the seller tells you in the ad plus they have probably stuck the sensor behind somewhere as its not very big
Post #181328 4th Apr 2013 8:51pm
