![]() | Home > Maintenance & Mods (L322) > Bluish Smoke From under the Front |
Just noticed over the last couple of days after driving the odd few short miles back and forth , once i have stopped some bluish smoke comes out from underneath the front of the car , have checked under the bonnet for any oil leaks or such but nothing , not even any leaks as such underneath the car .... |
XXXAngelXXX Member Since: 25 Mar 2007 Location: Stuttgart Posts: 4995 ![]() ![]() ![]() |
is it very cold outside where you live ? All my spelling errorz are belong to me!
stan Site Moderator Member Since: 13 Jul 2010 Location: a moderate moderated moderator moderating moderately in moderation Posts: 35641 ![]() ![]() |
fbh? ... - .- -.
Richcl Member Since: 23 Sep 2010 Location: Tewkesbury, Glos Posts: 1011 ![]() ![]() ![]() |
If it's a diesel check your engine breather has been replaced, preferably with the updated cyclonic type, mine did this before replacement with later type.
Rob2529 Member Since: 22 Nov 2010 Location: Wirral, uk Posts: 1470 ![]() ![]() ![]() |
Pending doom
Martin Site Admin Member Since: 24 Mar 2007 Location: Hook Norton Posts: 1668 ![]() ![]() |
FBH |
DaWalley Member Since: 24 Jan 2013 Location: Cheshire Posts: 42 ![]() ![]() ![]() |
Mine does it after short trips and mine is definitely from the FBH RR Vogue TDV8 08 |
I don't use the FBH … As its not working .. |
Could also be cleaning out the DPF maybe it needs a good hard drive to clean it out especially if doing short journeys just a thought Present :2008 TDV8 HSE
fbh not working and blue smoke , could be a connection.. ... - .- -.
Maximum daily drive to work and back 2.14 miles or 8 minutes |
FBH has not been working since November last year … |
would the fbh be 'trying' to fire up Mick? ... - .- -.
Not sure Stan coz since it wouldn't work i took the remote off the key chain months ago as well and there is nowt selected on the dash timer …. |
Mick read this re dpf
