Home > Maintenance & Mods (L322) > 07-09 indicator stalk to fit a pre-06?
Stryke
United Kingdom 2006 Range Rover Vogue SE Supercharged Java Black
I noticed that the 07-09 allows you to tap the indicator stalk and it gives a few flashes, a feature the pre-2006 models doesn't have.
If I fit this unit to my 06 will it work, is it in the switch or something in the ecu?
Post #181209 4th Apr 2013 12:47pm
TheAllSeeingPie
United Kingdom 2007 Range Rover Supercharged Supercharged Java Black
It's a function of the Light Control Module I think and not a hardware item.
07 Supercharged - Still breaking her in!
Boot soundproofing part 1 - http://www.fullfatrr.com/forum/topic15612.html
Custom exhaust - http://www.fullfatrr.com/forum/topic15296.html
18" wheels for Brembo equipped cars - http://www.fullfatrr.com/forum/topic15052.html
Post #181210 4th Apr 2013 12:57pm
if your lcm hasnt got that feature then it wont work, even the IIDTool wont switch it on if its not option on the ecu.. ... - .- -.
Post #181219 4th Apr 2013 1:22pm
ebajema
The three flash option is programmed in the ECU (the LCM in this case) as far as I know. Maybe if you upgrade the LCM or the LCM software you can get it. I turned it on on my car and it didn't work. I do plan to update the LCM software if I get my bloody flash file loader working and there is newer software available. If that works, I will let you know whether the 3 flash works.
Edit: no update software for the LCM. MY 2010 5.0 SC Galway green and sand interior!!
Post #181224 4th Apr 2013 1:59pm
Googsy
Thats why RR drivers from 07 on have more friends Thumbs Up Present :2008 TDV8 HSE
Gone Audi A5 2.7TDI
Gone Discovery 3 HSE
Gone Mercedes CLK
Gone Range Rover 2.5 DSE
Post #181251 4th Apr 2013 3:44pm
mzplcg
Are you sure it's in the LCM ?? I know that enabling this on a Discovery 3 requires a flash of the Body Control Module.
Post #181301 4th Apr 2013 6:34pm
spanner
Get a intravee its an option in there
Post #181308 4th Apr 2013 7:01pm
its a most system so afaik the intrevee wont work. ... - .- -.
Post #181310 4th Apr 2013 7:06pm
spanner
Does the most cover all the ecus as I thought it was only the nav audio im thinking the Ibus is still there
Post #181311 4th Apr 2013 7:12pm
done a search on here re intravee and all of the threads refer to the pre touch screen ranges.. ... - .- -.
Post #181313 4th Apr 2013 7:30pm
Stryke
Thanks for the replies.
Guess it's a no go.
Shame, nice feature to have.
Post #181382 5th Apr 2013 2:58am
Re: 07-09 indicator stalk to fit a pre-06?
Get an 07> M.Y. car, not only will you get a new car & three flash indicators but you'll also get some more friends... See above Whistle Whistle Whistle Laughing
Craig Laughing
Post #181397 5th Apr 2013 9:34am
