Home > Maintenance & Mods (L322) > Royal grab handles
Page 2 of 3 <123>
ebajema
Back on topic, our Landcruiser has grabhandles in the top corner of the door opening. They are a rigid type and looks like it is bolted into the pillar and the roof "girder". They are quite handy when hauling yourself into the back. Maybe have a look for those ??? MY 2010 5.0 SC Galway green and sand interior!!
Post #180846 2nd Apr 2013 8:07am
ebajema
Found this online, not on a LC but on a Montero.
http://www.expeditionportal.com/forum/thre...rowd/page5
If you use Google Images and type in Montero Grab handle, you will find some more pics. MY 2010 5.0 SC Galway green and sand interior!!
Post #180847 2nd Apr 2013 8:14am
Rich86
United Kingdom 2009 Range Rover Vogue TDV8 Nara Bronze
Had a look at the link but think I will look into mounting them with the standard type handle albeit more of a challenge...
Post #180998 3rd Apr 2013 8:23am
ebajema
I looked at my LC ones yesterday and they only have two holes in the "roof girder". MY 2010 5.0 SC Galway green and sand interior!!
Post #181002 3rd Apr 2013 8:54am
You'll be going for the Royal Flush next Mick Laughing Laughing
Post #181015 3rd Apr 2013 9:59am
Tim in Scotland
Location: Somewhere between here and there, if not then I'm all at sea or at home in Scotland
2010 Range Rover Vogue TDV8 Stornoway Grey
No optional extra red carpeted mounting block or deployable sidesteps for the Royal FFRR then? Would be much more elegant for her madge than sliding off the rear bench while holding a grab handle............ 2018 Mini Countryman Cooper S E All4 PHEV in Melting Silver - it’s whisper quiet in EV and polluter modes
Post #181018 3rd Apr 2013 10:07am
@Rich86
The chances are you could drill the centre post and fit Rivnuts to it.
Trouble with Rivnuts is they may work loose with the continious pulling.
Personally I would take the trim off and tack weld a steel plate strip to the post about 4mm thick then drill and tap the plate and the post behind to take the bolts holding the handle. Then refit the trim.
You will need to fit a spacer thro the bolt holes in the trim to get a solid fix, a stack of washers would probably do this.
Post #181020 3rd Apr 2013 10:13am
can i ask why you need grab handles, is it for access and will an alternative like side steps be any good.. ... - .- -.
Post #181021 3rd Apr 2013 10:19am
TheAllSeeingPie
United Kingdom 2007 Range Rover Supercharged Supercharged Java Black
The Queen probably doesn't have sidesteps as they get in the way off-roading!*
* It's more plausible they can't make armoured sidesteps ...
07 Supercharged - Still breaking her in!
Boot soundproofing part 1 - http://www.fullfatrr.com/forum/topic15612.html
Custom exhaust - http://www.fullfatrr.com/forum/topic15296.html
18" wheels for Brembo equipped cars - http://www.fullfatrr.com/forum/topic15052.html
Post #181023 3rd Apr 2013 10:25am
Rich86
Stan it's the mother-in-law - she's elderly and yes side steps are an option that I'm looking into...
Post #181024 3rd Apr 2013 10:27am
reading these posts it sounds like the grab handles might not be an option and side steps would probably benefit everyone .. ... - .- -.
Post #181026 3rd Apr 2013 10:44am
They do stick sidesteps on armoured ones but its PITA job as usually the mounting plates tend to be covered up by plating so require re-working and then usually shatter into a gazillion bits during testing.... FFRR MY06 facelift With TDV8 Alloys Zeros/ATR's
Post #181040 3rd Apr 2013 1:10pm
ebajema
The sidesteps do help but a grab handle still helps a lot, even with sidesteps. MY 2010 5.0 SC Galway green and sand interior!!
Post #181044 3rd Apr 2013 1:36pm
Im so sad Mick hasn't popped on this yet that i will have to do something in his place...
I was hoping for these grab handles too... Smile
Post #181063 3rd Apr 2013 2:29pm
if fixing the grab handles is to much of a problem ,you could fasten a strap on some kind to the front seat base .. ... - .- -.
Post #181064 3rd Apr 2013 2:33pm
Page 2 of 3 <123>
