![]() | Home > In Car Electronics (L322) > 03 Vogue Subwoofer |
dannyp15 Member Since: 21 Sep 2011 Location: essex Posts: 244 ![]() ![]() ![]() |
i had the subwoofer rattle/vibration for ages then i found out it was the woofer vibrating against the trim in the boot so i got a bit of cardboard and stuck it between the woofer and the trim and it stopped |
Pedrochellie Member Since: 23 Feb 2012 Location: Surrey Posts: 82 ![]() ![]() ![]() |
Lol - I tried that too! Unfortunately it keeps rattling loose!
Lolo Member Since: 16 Feb 2012 Location: Leinster Posts: 608 ![]() ![]() ![]() |
I have harmon kardon and there is an option in the screen for the sub woofer volume.
FrankRizzo Member Since: 27 Aug 2012 Location: Frankfurt am Main Posts: 218 ![]() ![]() ![]() |
You could try a dab of bathroom sealant on the bolt threads. Should prevent screws or bolts from loosening through vibration (once set) without preventing you from undoing them again, should you need to. |
vnitos Member Since: 18 Nov 2010 Location: pretoria Posts: 390 ![]() ![]() ![]() |
also have the rattling subwoofer - tightened up the screws, using a bit of silicone between speaker and housing as well as bit on screws itself - its better but not totally gone
Joe90 Member Since: 29 Apr 2010 Location: Hampshire Posts: 6414 ![]() ![]() |
IIRC to remove the "trim casing" panel:
