Home > Technical (L322) > How to open the 'clamshell' to replace worn compressor. |
piersie Member Since: 18 Dec 2010 Location: Berks Posts: 97 |
Thanks , I am pretty sure that this is the fix i need.
20th Mar 2013 1:15pm |
Rob2529 Member Since: 22 Nov 2010 Location: Wirral, uk Posts: 1470 |
I think ou will be surprised how long it lasts. I stripped mine and sanded the sealing face on my old ring and applied some vac grease and mine was still going strong before I sold it so was ok for about 8months. You have new piston rings so I guess will last even longer! [img]http://www.fuelly.com/driver/rob2529/range-rover[img/]
22nd Mar 2013 3:04pm |
Okay my piston ring arrived this morning,so went and fitted it,it was simple after reading this thread , and the only problem i would of had is removing the clam shell.
22nd Mar 2013 4:04pm |
rgwatches Member Since: 19 Dec 2012 Location: United Kingdom Posts: 36 |
I had a height issue (front way to high, back a little high) but could not re calibrate with RSW all comms due to the lazy pump, now since the new piston ring I have successfully re calibrated and all is working perfectly! |
25th Mar 2013 1:02pm |
muffster Member Since: 03 Dec 2011 Location: Bradford Posts: 71 |
Hi mate, I'm just about to do exactly the same job.
25th Mar 2013 6:05pm |
Hi,
25th Mar 2013 8:02pm |
Great thanks.
25th Mar 2013 8:43pm |
Hello again mate.
27th Mar 2013 12:46pm |
Afternoon,
27th Mar 2013 12:49pm |
nicedayforit Member Since: 11 Jun 2011 Location: Beside the Solway Posts: 3979 |
If I'm not mistaken, to avoid any problems with fault codes when working on the compressor it is advisable to disconnect the battery before disconnecting the power to the compressor.
27th Mar 2013 1:24pm |
I didnt personally do that and had no issues (I did do a reset with RSW prior), but it seems like a sensible precaution. |
27th Mar 2013 1:32pm |
Gents,
27th Mar 2013 5:08pm |
Have you disconnected the battery, leave it 15 mins, then reconnect and move to wheel from lock to lock a few times as previously suggested?
27th Mar 2013 5:10pm |
Hi mate,
27th Mar 2013 6:23pm |
