Home > General > Snow and Ice
Page 3 of 3 <123
dan_uk_1984
speedymarktd6 wrote:
all above very interesting BUT ive been told by a landrover experience instructor that the dsc button shouldnt have been fitted to production vehicles as you shouldnt have the option to turn off as the button is not needed as the electronics do all the work
Wow, was he mentally retarded or something??
You MUST use DSC if you're in deep ruts and there is any danger of becoming partially beached. If the DSC senses slip and backs off the throttle as your passing over a slightly higher bit then you'll be completely stuck and you will have lost all momentum that would have otherwise got you through.
If you're starting off in deep sand, or uphill in sand you MUST disable DSC because again it will cut all power and you'll end up bogged down and going nowhere. Or as you're driving along and you get to a deep bit of sand the DSC will cut in and you'll instantly stop.
I've already described slippery climbs as above, but slippery flat can have the same effect - Going nowhere.
The button is there for a very good reason - it's a system that was developed for a BMW saloon - it doesn't translate that well to SOME off road situations. That's why terrain response was developed as you cant expect the moron behind the wheel to remember to turn DSC off.
What your instructor probably meant was that no RR needs it because it never goes off road. I'm fed up of dealerships scoffing at the idea that Land Rovers go near the rough stuff. When I was 18 I wanted a Freelander (I know the shame of it) and when I mentioned its off road ability the LR dealer laughed and literally said "you'd have to be stupid to take these off road". That was from a proper LR dealer.
Post #11772 26th Jan 2010 8:11pm
speedymarktd6
United Kingdom 2010 Range Rover Vogue SE TDV8 Santorini Black
sounds right, ive never had any major issues offroad that i couldnt sort out Thumbs Up onto no6 Range Rover
Everyone needs a hobby
Post #11775 26th Jan 2010 8:54pm
Please I have terrain response as I guess switching off DSC is no longer required although the button is still there....
Post #11777 26th Jan 2010 9:25pm
dan_uk_1984
what does your manual say?
Post #11778 26th Jan 2010 9:29pm
RRVSE
United Kingdom 2013 Range Rover Vogue SDV8 Corris Grey
Hi Dan, I stumbled across this article today through the day and tested the 10sec DSC off option which worked, however, I want to turn it back on now but can't. Held the button for 10secs again thinking it would reverse it - no luck, turned engine off and then back on 5-6secs later, but still unable to enable the 'dsc' button i.e. can't get the green dsc display to appear on dash. What am I doing wrong? Sad Steve
Main car : FFRR L405 Vogue SDV8
Other car : Vauxhall Lotus Carlton
Past cars : FFRR L322 Vogue TD6 SE (Sept 2006 MY07) ; LandCruiser SWB ; 4-Runner ; Supras; XJS V12 LeMans
Post #17989 9th May 2010 12:14am
dan_uk_1984
It should reset next time you start the car. It's designed so it's a pain in the ass to disable - so people don't kill themselves.
I take it though you've tried ign off and on?
Post #17990 9th May 2010 12:17am
RRVSE
Cheers Dan , glad you're online, it would have annoyed me all night. I guess I didn't leave the engine turned off long enough. I'll nip out now and give it a go again! Ta Very Happy Steve
Post #17991 9th May 2010 12:23am
RRVSE
Hi Dan, you're correct of course. Just started car up and all back to normal. You'd think you would be able to enable it again without turning the engine off. Anyway, I'm happy now. Cheers Very Happy Very Happy Steve
Post #17992 9th May 2010 12:26am
Page 3 of 3 <123
