Home > Technical (L322) > Not used a drop of oil...is that normal?!
jfb1977
England 2011 Range Rover Vogue SE 4.4 V8 Santorini Black
I've had my car getting on for a year now and it was serviced by Land Rover the day I picked it up.
I've probably done about 13,000 miles in the past year and have never needed to top up the oil level.
Given that it's getting near annual service time, I checked a few things like tyre treads etc and once again checked the oil level. It still doesn't seem to have used a drop. The level is still bang on.
The car is a 2007 4.2 S/C - is that normal? I've never had a car that doesn't seem to use any oil.
Confused Question Past (too many to list, but a few favs)...
2007 Porsche 997 C2S Coupe
2007 FFRR 4.2 S/C
2012 Jag XKR 5.0 S/C
2014 Merc SL500 AMG 4.7 V8 BiTurbo (remapped to 560BHP)
2011 FFRR 4.4 TDV8 Vogue SE - Overfinch Conversion
2012 Porsche Cayenne Turbo
2018 AMG C63S Estate
2015 Mercedes GLE63S
2017 Maserati Levante Diesel
2017 Audi A6 Avant 3.0 Black Edition
Post #179741 26th Mar 2013 11:50am
ebajema
Mine doesn't either, the oil just turns darker over time. In most cars there is always a little bit of petrol going into the oil (piston rings, valve seals) that then enters the engine oil making it seem it doesn't use any. Same way some of the engine oil goes into the combustion chamber and is burned there.
LPG cars don't have the petrol mixing and therefore show the oil usage better. MY 2010 5.0 SC Galway green and sand interior!!
Post #179747 26th Mar 2013 2:18pm
ambulancekidd
Scotland 2005 Range Rover Vogue Td6 Oslo Blue
Its a similar situation with diesels but the situation can really catch out the unwary. The oil in the sump becomes so diluted with diesel that the thinner mix finds its way past the turbo seals & you have a runaway situation so
switching the engine off makes no difference. Shocked
With a manual vehicle you might manage to stick it in gear & with your foot hard on the brake stall the engine but that only works if the clutch holds together. In an automatic your goose is cooked, simply stand well clear & await the sump running dry, at which point there will be a very expensive bang & a new engine is required. Whistle
Isn't life so very full of surprises Bow down The reason women's minds are cleaner than a mans mind is that women change their minds more often!
When women say fine a mans in deep doodoo as fine has so many meanings.
Post #179774 26th Mar 2013 6:45pm
Katash
England 2007 Range Rover Supercharged 4.2 SC V8 Zermatt Silver
Saw this a few months ago on Youtube
Post #179788 26th Mar 2013 7:15pm
