Home > In Car Electronics (L322) > 07 rear door panel removal |
SATVC Member Since: 25 Nov 2012 Location: Surrey Posts: 172 |
If its the same as an 04
24th Mar 2013 8:54am |
Joe90 Member Since: 29 Apr 2010 Location: Hampshire Posts: 6414 |
Video link in the wiki
24th Mar 2013 9:28am |
SFM Member Since: 19 Feb 2012 Location: dordogne Posts: 258 |
Ive bloody tried this 4 times now! mine is slightly different from the video, on mine there are 3 screws, and once removed, pop the fixings.. but there seems to be something in the middle of the panel holding it to the door,VERY FRUSTRATING!! should be a simple repair job, once removed. |
24th Mar 2013 6:04pm |
Cam-Tech-Craig Member Since: 03 Aug 2011 Location: Gloucestershire Posts: 16306 |
Lift the trim when its hanging off as its sat on a large plastic pop clip in the middle that often will not pull apart, but lifting the panel slides it out of the panel... Remember to pop it off with a trim tool and refit it to the door card before you re-install
25th Mar 2013 12:37am |
Right..at last, someone who`s done one!
25th Mar 2013 9:29pm |
Bump! |
27th Mar 2013 5:31pm |
Have you removed the screw in the door handle?
27th Mar 2013 7:01pm |
On mine, an 07 TDV8 vogue with logic 7 sound, the panels are different from the TD6 i think.
28th Mar 2013 10:45am |
Here is an image from the 07-10 workshop manual
28th Mar 2013 9:54pm |
You need to remove four screws in total 3 in the cars itself and the 4th is hidden behind the LandRover badge... |
29th Mar 2013 10:25am |
HOORAH!!!!!
29th Mar 2013 7:06pm |
TheAllSeeingPie Member Since: 18 Apr 2012 Location: Leeds Posts: 848 |
I struggled with the central black clip today, took all 4 door cards off and applied copious amounts of sound deadening. Even did my lower tailgate while I was at it
29th Mar 2013 7:15pm |
stan Site Moderator Member Since: 13 Jul 2010 Location: a moderate moderated moderator moderating moderately in moderation Posts: 35463 |
is not the 2007 s/c very quite anyway mr p. ... - .- -.
29th Mar 2013 7:16pm |
It's already very quiet, but I had some extra soundproofing foam left over from another project so decided to fit it. The car is amazingly quiet now, even with the bonkers exhaust on it.
31st Mar 2013 7:20pm |
