Home > Technical (L322) > Steering column tilt problem
Scorchio
United Kingdom 2003 Range Rover Vogue 4.4 V8 Buckingham Blue
Just bought a 2003 Vogue 4.4 ... will post pics after I've given it a nice polish !
Tested everything before buying and found the steering wheel tilt inoperable. Funny how the seller didn't mention it ...
Anyway quick call to Hunters in Derby and they quoted around £350 to repair.
So got the seller to knock this off the total and took the car ... Very Happy
The column is actually spot on for me, and to be honest i could live without getting it sorted.
Anyone tell me the cheapest and easiest method to get this sorted ? ... oh and I'm no mechanic and wouldn't dream of attempting this myself - unless it was very straightforward.
Spotted these on ebay.com (USA) - item no. - eBay Item No. 300424176208
Sheep Sheep Sheep
Post #17868 5th May 2010 12:04pm
JW911
United Kingdom 2012 Range Rover Westminster TDV8 Zermatt Silver
Can't help with cheap and easy fixes. However, once you have it sorted, my advice is to motor it forwards and upwards until it's at the end of it's stops and doesn't move when you put the key in. Adjust your seat so you're in the right place without the wheel having to move and Robert is your mother's brother. They do have a tendency to fail so this prevents unnecessary wear and tear.
Post #17869 5th May 2010 12:08pm
DeltaC
Odds on, its jammed not broken. There is a nut on the end of the worm gear that tightens and then prevents it from turning.
So, take the panel off below the steering wheel (few screws etc) then look upwards - You will see a worm gear running right to left with a 13mm nut on the end nearest the drivers door. Gently back it off half a turn and try the tilt.
To prevent it happening again, I removed the single nut and fitted two narrower ones then wrung them together so they locked. Alternatively, you could clean the threads and try loctite.
Hope this is all it needs!
DC
Post #17874 5th May 2010 5:09pm
Andy
Rather than start a new thread on this - does anyone know how to lubricate the column? Mine makes a noise when its retracting when switched off. Sounds like it needs oil. 2010 MY Vogue SE TDV8 3.6 Stornoway Grey- fully loaded
Post #17881 5th May 2010 7:06pm
Scorchio
Oh forgot to mention - mine does this too ! 2003 Vogue 4.4
2005 BMW 330d
Gone - 2002 TD6 HSE
Post #17884 5th May 2010 7:25pm
SGW
United Kingdom 2009 Range Rover Autobiography 5.0 SC V8 Stornoway Grey
I used a long artist's brush about 1/4" wide with grease on it and lubricated the screw mechanism. Noise gone.
Stewart.
Ooops, forgot to mention have to remove the lower column cover of course.
Post #17893 5th May 2010 9:09pm
SteveNorman
If lubing the screw thread doesn't work, try a small squirt of WD40 (or teflon spray) on the bit where the shaft turns by the motor end, (you can see the spindle spinning round there), as these tend to cause the eek, eek eek noise. You know when you have found the right bit as the noise goes away Laughing
Regards
Steve
Post #17918 6th May 2010 11:02am
This is a great post guys but some pictures would be very useful for everyone...anyone got any of the work? Discovery 4 HSE
Post #17928 6th May 2010 5:36pm
CyberMrT
2003 Range Rover Vogue 4.4 V8 Stornoway Grey
This is not really maintenance but shows what happen when mine actually broke, the metal tab snapped Big Cry
Post #17929 6th May 2010 6:23pm
M44K TS
Funny this thread should come along, I freed mine off last week, I forgot to take some pics as I was going to do a 'how to'.
Makes the car so much more comfortable to drive. 2006 Mercedes CLS
1991 Retro-style Mini
But really finding it hard to fight the urge for a S/C...
Post #17931 6th May 2010 9:05pm
doublejay
..wait, are we saying there;s more adjustment available if you tweak underneath ?
Post #17937 7th May 2010 8:18am
M44K TS
Don't know abuot extra adjusment, but if I lower mine right down, it crushes my legs Laughing 2006 Mercedes CLS
Post #17950 7th May 2010 2:48pm
Andy
I'm being v lazy now- how do you get at the mechanism to lube it? 2010 MY Vogue SE TDV8 3.6 Stornoway Grey- fully loaded
Post #18055 10th May 2010 2:15pm
M44K TS
There's 3 torx screws on the under side of the shroud, the top 2 should be esy enough to get at with uninsulated torx screwdrivers, but the one at the bottom by itself is tucked right in, I found a couple of 3/8 extensions from a socket set with a torx bit on managed to reach it no problem. Once the screws are out, lift the top section up and outwards (If I remember rightly!!) The lower one will drop down too, then lookin up from underneath the steering colum, the spindles are right infront of you.
Clipping te shrouds back together was a bit fiddly, especially the leather trim between the dash and the shroud.
All together, should take no longer than 20 mins to do the whole lot, alot of the time is spent swearing at the stupid flap of leather. 2006 Mercedes CLS
Post #18077 10th May 2010 9:24pm
