![]() | Home > Wheels & Tyres > My FFRR is useless offroad |
ChrisR Member Since: 08 Dec 2012 Location: Oxfordshire Posts: 17 ![]() ![]() ![]() |
When grass becomes this slick!!!!!!!!!!! |
Well that ones been around about 3 years! Big debate on whether its real or not... |
AJS4X4 Member Since: 08 Jun 2012 Location: Surrey Posts: 276 ![]() |
Lots of customers going for the 275/45x20 option, General AT and Cooper LTZ are good choices. |
mikef Member Since: 30 Jan 2013 Location: Bucks Posts: 82 ![]() ![]() ![]() |
How does that affect the ride compared to 255/50? How would the LTZs compare to the Contis in terms of on road handling and noise? They're a much chunkier tread pattern |
Well all I can say is that we have fitted both but mainly the General AT and have not had any negative feedback on either, I am sure others will be along soon.
As per earlier in the thread I have run several tyres in the 275/45 x 20 and ride is excellent due to the wider tyre. The rolling radius is nearly identical and due to the wider tread and a slightly smaller sidewall the handing improves. All in all a good choice in my opinion as there are lots more tyres to choose from. |
Philip Member Since: 05 Jan 2010 Location: UK Posts: 2607 ![]() ![]() |
You will inevitably face a trade off in noise and on-road performance with a more off-road biased tyre - in normal day-to-day use you probably won't notice a huge amount of difference with an AT tyre, but under test conditions you would expect to see worse wet and dry road grip and braking performance (and worse fuel consumption).
