Home > Maintenance & Mods (L322) > Suspension
djmac909
United Kingdom 2014 Range Rover Autobiography 5.0 SC V8 Santorini Black
Suspension
I recently had a rear end shunt – now full repaired by an authorise LandRover dealer – but im sure that the car is sitting a little lower at the rear. I don’t think there is a problem with the repair, I’m thinking the suspension hasn’t been reset. Is there a way to reset this? I recall having an issue once when I changed a wheel and the suspension locked at an unusual height. Any ideas? L405 S/C Autobiog
Post #178945 21st Mar 2013 5:10pm
They naturally sit that way. Maybe your just being more critical now after the repair. Do you have any lights on the height display? Take it back to LR they will reset it or re-calibrate it to the correc heights. [img]http://www.fuelly.com/driver/rob2529/range-rover[img/]
Post #178986 21st Mar 2013 7:45pm
The 2007 should sit pretty level compared to the older cars that did sit down a bit at the back....
Post #178997 21st Mar 2013 8:16pm
Measure from centre of wheel to bottom of wing on front and back and on both sides and report back.
Should be:
493 front +/- 2mm
483 back +/- 2mm
Although a little more variation is not unacceptable. .
Post #179024 21st Mar 2013 11:02pm
