Home > Maintenance & Mods (L322) > Mot got more difficult to pass today
Few items relevant to FFRR's,
http://www.theaa.com/motoring_advice/car-s...-2012.html
Post #178688 20th Mar 2013 6:26pm
They can only check for warning lights not if systems are actually working. Only £50 after all!
Post #178704 20th Mar 2013 6:54pm
taskam
Scotland 2007 Range Rover Vogue SE TDV8 Java Black
While on the subject of MOTs, MOTEST in Swindon (and I guess other locations) don't charge for a failed MOT, you only pay when it passes. Very useful for me getting my son's 03 Clio with 180k miles on the clock through last time Laughing 2007 TDV8 Vogue SE Java Black
Post #178708 20th Mar 2013 7:02pm
The trouble with warning lights is they are usually accurate, if a warning light is on the system is faulty. Thumbs Up
Post #178749 20th Mar 2013 8:11pm
barracuda816
United Kingdom 2005 Range Rover Vogue SE Td6 Tonga Green
Thats the problem with these pesky new cars,you cant just take the bulb out likke you used to!
Big Cry
Post #178763 20th Mar 2013 8:42pm
Reformed
Allthough not Range Rover related, I had to replace a module on a Vauxhall that the dealers wanted £850 to swap and programme.
I got a used one for much less, which worked, and fitted it myself, but it threw up an ABS warning light. The car did not have ABS but as the module came from a car that did, it was trying to communicate to the ABS module and because it was not getting a signal back it put the light on.
The dealer wouldnt re-programme it to the car as I did not buy it from them, so I used black tape to cover the bulb (its an led strip, behind the dials so they obv. Use the same speedo across the range.
Went through the MOT Thumbs Up Reformed
Post #178767 20th Mar 2013 8:49pm
Censored TPMS is on the list
What are my options for getting it switched off - IID tool I suppose - anything cheaper ?
Post #178770 20th Mar 2013 9:13pm
Hope HDC INACTIVE isn't on the list or we are all b Censored d Laughing .
Post #178772 20th Mar 2013 9:22pm
@ Alistair
You don't need to get it switched off, your car won't be tested on it.
Only applies to cars registered after 1 Jan 2012.
Post #178773 20th Mar 2013 9:23pm
Post #178779 20th Mar 2013 10:01pm
Andy
1st Jan 2012 was when the new items for test were devised. It was never actually mandatory until yesterday.
Post #178791 21st Mar 2013 8:22am
bigee
wonder if the cost of the Test will rise ? will surely be a case of claiming the test will take longer for garages to do so less capacity? Shocked
Post #178794 21st Mar 2013 8:35am
Andy
Mine failed on the airbag light yesterday Evil or Very Mad
Post #180574 31st Mar 2013 11:52am
If you'd taken it for a test before the 20th it would have passed. Thumbs Up
Post #180579 31st Mar 2013 1:22pm
My old man just got his crossfire through last month with an Stability control light on, probably wouldnt go through now.....
They cant find the problem at the garage. i have suggested a lateral acceleration sensor but he doesnt believe me.......thinks all these new fangled gizmos are all "cr*p" and why cant cars be as simple as they used to be.
I then pointed out his car of choice used to be a turd brown classic with "over" 100k on the clock which never passed it mot first time and usually required welding or carb adjustments or new exhaust or new bushes or........ No further comment was forthcoming. There is nothing that can't be fixed with a hammer😜😜
Post #180585 31st Mar 2013 2:43pm
