Home > Technical (L322) > EPB Adjustment (SOLVED - HOW TO INSIDE!)
Katash
England 2007 Range Rover Supercharged 4.2 SC V8 Zermatt Silver
Does anyone know if the procedure in RAVE for setting up the handbrake shoes is the same on vehicles with electronic brakes? .... When i changed my rear discs I set them up to the required 8 clicks but doesnt seem very effective .... Motor seems to travel for longer now when applying too.
Post #178578 20th Mar 2013 1:07am
Autobiography
2018 Range Rover SVAutobiography 5.0 SC V8 Santorini Black
Re: EPB Adjustment
EPB is self adjusting AFAIK.
Post #178585 20th Mar 2013 8:01am
Katash
Found this from TOPIX
Quote:
Parking Brake and Actuation - Parking Brake Shoes Bedding-In
General Procedures
� NOTE: This procedure must be carried out if, new parking brake shoes are fitted, new rear brake discs are fitted or if the vehicle has been mud wading (not water) for more than 50 miles.
1. Carry out the parking brake shoe bedding-in procedure.
2. NOTE: The parking brake shoes 'bedding-in procedure' mode will remain active for the remainder of the ignition cycle, or until the vehicle speed exceeds 31 mph (50 kph). If the procedure needs to be re-entered, the entry actions must be repeated.
To enter the parking brake shoes 'bedding-in procedure' mode.
Start and run the engine.
Apply the brake pedal 3 times within 10 seconds and hold applied after the 3rd application.
Apply the electronic parking brake switch 4 times, followed by 3 release applications within 10 seconds.
3. Once the parking brake shoes 'bedding-in procedure' mode has been entered, the parking brake warning lamp will flash and the parking brake shoes can be bedded-in. Conduct 10 repeated stops from 30 - 35 kph (19 - 22 mph), followed by a 500 metre (547 yard) interval between each stop to allow the parking brake actuator and rear brakes to cool.
The electronic parking brake brake force will be increased up to the dynamic maximum so long as the switch is held in the applied position.
If the switch is released to either the NEUTRAL or OFF positions, the electronic parking brake will be released.
The parking brake actuator and rear brakes MUST be allowed to cool between applications, either by driving at 19 mph (30 kph) for 500 metres (547 yards) or remaining stationary for 1 minute between each application.
I didn't do this after changing my rear discs, maybe I need to do it - Has anyone done this?
Post #180139 28th Mar 2013 7:51pm
Katash
Just completed this procedure, works exactly how it says, now the EPB seems to be set up correctly, basically beforehand the EPB would hold the car whilst on a slope and in neutral and would hold the car while in reverse but not hold the car while in drive - now it works perfectly.
I had no idea you had to do this procedure - maybe work WIKI'ing it?
Post #180145 28th Mar 2013 8:09pm
I did it with my manual handbrake after changing brake shoes.
I do a more extreme version for the brake pads, 60 > 0 hard braking 5/6 times. .
Post #180164 28th Mar 2013 10:59pm
Katash
This procedure seems to calculate and alter how much force is applied by the servo
Post #180165 28th Mar 2013 11:13pm
