Home > Maintenance & Mods (L322) > Privacy glass
Rich86
United Kingdom 2009 Range Rover Vogue TDV8 Nara Bronze
Privacy glass
Does anyone know whether the black privacy glass fitted to my 2002 l322 is standard? If it is does this mean it is solid black and not a coating like aftermarket films? If it is an aftermarket film then I'm assuming it can be removed without damage to reveal the green tint below?
Post #178246 18th Mar 2013 7:51pm
CMJ
2015 Range Rover Autobiography TDV6 Santorini Black
Easiest way to tell - can you clearly see the rear screen heater elements from the outside of the car ? If clearly can be seen then this is likely yo be film and can be removed with a hair dryer. If cannot be seen clearly and you have to look really hard into the glass to to see them then this is factory tint and cannnot be removed 2013 L405 AB 4.4SDV8 Luxor/Ivory, 2007 Vogue TDV8 Epson Green/Sand, 2008 Vogue TDV8 Buckingham Blue/Sand, 2003 Vogue 4.4 LPG Epsom Green/Sage, 1998 Vogue SE 4.6 LPG Epsom Green/Cream
Post #178253 18th Mar 2013 8:14pm
CMJ
Post #178254 18th Mar 2013 8:14pm
Assuming you want to remove film if fitted, drag a sharp nail across the inside surface of a side window. Tinted film will mark, glass won't.
Post #178258 18th Mar 2013 8:19pm
Rich86
Ok will check tomorrow. Was privacy glass standard on some of the early l332 vogues?
Post #178268 18th Mar 2013 9:10pm
Mr Tee
Factory privacy was an option from 2002.
Post #178271 18th Mar 2013 9:34pm
Rich86
It's factory glass so not much can be done abut it.
Post #180699 1st Apr 2013 1:05pm
Rear window! If it breaks into a zillion pieces its factory, if it breaks but you can see the film holing it together its aftermarket stuff. :thumbsup:
Admin note: this post has had its images recovered from a money grabbing photo hosting site and reinstated Mr. Green  [img]http://www.fuelly.com/driver/rob2529/range-rover[img/]
Post #180782 1st Apr 2013 6:42pm
Rich86
If it can be broken with a hammer...
Post #180784 1st Apr 2013 6:44pm
park it in a dodgy area next to a pile of bricks....... Wish mine was factory, looks ok just one of those things which bugs me.
How come you want to get rid of it? There is nothing that can't be fixed with a hammer😜😜
Post #180930 2nd Apr 2013 4:49pm
Rich86
I'm in two minds. Sometimes I prefer the look of the green tinted all round...
Post #180934 2nd Apr 2013 5:22pm
RRBlue
England 2005 Range Rover Vogue SE 4.2 SC V8 Buckingham Blue
I have come to the conclusion that when the first ball joint or bush wears out, its best policy to replace the lot on that axle. The chances are that the rest are not far behind and the effect if one bush or joint malfunctioning hastens the demise of the rest. May as well have one miserable makor expense, rather than the a catalogue of failures thAt feel like dripping tap torture. Do it all once and there is only one set up and finish cost.
Post #180958 2nd Apr 2013 8:08pm
