Home > Technical (L322) > Key programming - key lost program
CMJ
2015 Range Rover Autobiography TDV6 Santorini Black
All, Key 1 worked when I received the car. Key 2 didn't. The dealer programmed Key2. All worked fine but Key 1 now doesn't work. We have tried everything and no luck. Key functions in all other ways (starts car, opens door with lock etc)
Therefore my question is do I need to replace whole key or can I change the insides from another key and re-programme to my car recognising that must be the microswitches in one of the buttons
Thanks 2013 L405 AB 4.4SDV8 Luxor/Ivory, 2007 Vogue TDV8 Epson Green/Sand, 2008 Vogue TDV8 Buckingham Blue/Sand, 2003 Vogue 4.4 LPG Epsom Green/Sage, 1998 Vogue SE 4.6 LPG Epsom Green/Cream
Post #177472 13th Mar 2013 11:56pm
daz62
United Kingdom 2003 Range Rover Vogue SE 4.4 V8 Oslo Blue
The dealer probably hasn't sync'd the keys properly, I think you will find both keys work fine when sync'd to the car individually. Best test is to get him to sync the duff key for you.
You could try doing it yourself.
Reset Procedure for your key fobs
Every signal from the remote handset contains the transmitter identification code and a rolling code. The BCU checks
the codes and only responds if the signal is from a valid transmitter. During vehicle production, the remote handsets
supplied with the vehicle are initialised to set their individual transmitter identification codes and synchronise their
respective rolling codes with the BCU. If a transmitter loses synchronisation with the BCU, or if a replacement or
additional remote handset is to be used with the vehicle, the initialisation procedure must be repeated. During the
procedure, all remote handsets for use with the vehicle must be initialised.
Initialisation Procedure
1 Ensure the vehicle is unlocked and the driver and front passenger doors are closed.
2 Install a key/remote handset in the ignition switch, then turn the ignition switch to position I and back to position
0 in less than 5 seconds to put the BCU into the initialisation mode. Continue the procedure within 30 seconds
of turning the ignition switch to position 0.
3 Remove the key/remote handset from the ignition switch.
4 Press and hold the unlock button for a maximum of 15 seconds. During this time, momentarily press the lock
button three times within 10 seconds.
5 Release both buttons.
6 Successful initialisation is indicated by the BCU locking then unlocking the vehicle. If this does not occur, repeat
step 4.
7 Repeat steps 4 and 5 with all other remote handsets belonging to the vehicle (4 maximum). Begin the
initialisation of each remote handset within 30 seconds of completing the previous initialisation, or the BCU will
drop out of the initialisation mode and the complete procedure will have to be started again. 03 4.4 V8 petrol / lpg. 1st of many hopefully. I love my Rangie
Post #177487 14th Mar 2013 7:50am
both keys need to be synced at the same time.. ... - .- -.
Post #177493 14th Mar 2013 9:00am
ahebron
New Zealand
Don't know about 07 but 03 you can buy a complete cheap key of Ebay and swap the gubbins over. I have done this recently. Comes with better buttons.
Adrian VW Amarok 2014 Highline auto
Post #177691 15th Mar 2013 5:16am
CMJ
Thanks guys. Had tried the key re-programming approach and had realised that I need to do both. Problem is even following the correct approach I still cannot get Key 1 to register again. Therefore assumed this must have developed a fault. Hence the change the internals approach / enquiry.
CJ 2013 L405 AB 4.4SDV8 Luxor/Ivory, 2007 Vogue TDV8 Epson Green/Sand, 2008 Vogue TDV8 Buckingham Blue/Sand, 2003 Vogue 4.4 LPG Epsom Green/Sage, 1998 Vogue SE 4.6 LPG Epsom Green/Cream
Post #178045 17th Mar 2013 5:56pm
CMJ
Post #178046 17th Mar 2013 5:56pm
daveo
it can take a few goes to get it right, i think its very unlikely for both to go wrong.. V8 facelift Range Rover Autobiography 22" wheels.
Post #178053 17th Mar 2013 6:21pm
daveo
call me, i will talk you through it.. V8 facelift Range Rover Autobiography 22" wheels.
Post #178065 17th Mar 2013 7:07pm
Geo2toy
United Kingdom 2011 Range Rover Vogue SE TDV8 Java Black
I had this when I got a new key took a couple of times to get right as its all in the timing.
Post #179134 22nd Mar 2013 6:26pm
piersie
England 2003 Range Rover Vogue Td6 Epsom Green
Sorry to be a pain,but doing mine i had to hold it in lock position (if you hold the unlock button all you are doing is activating global locking and your windows will all open along with your sun roof.)
I synched both of mine seperately. Thumbs Up
Cheers Piers
Post #179166 22nd Mar 2013 7:56pm
zetjester
United Kingdom 2002 Range Rover Vogue Td6 Alveston Red
I have been trying to sync my new flip key! to my MY2005 Td6 (dec 2004)
Followed the others posts on this with interest, bought two flip keys from one of the oriental suppliers Wink
Had blade cut, swopped transponder over and bingo the key starts ignition Smile
But I cannot program to open doors Big Cry must have tried the program procedure a couple of dozen times now, my original keys still work ok and will program fine but the flip one just don't wonna know
I have tried programming them in a different order also Crying or Very sad
Do the flip keys get sych'd differrently or will I need to go to my Indie dealer and have them try to do it?
I dont think the unit is at fault as I have switched the inner gubbings from the second key over and can't make it work that way either.
Any help most appreciated Thumbs Up
Post #189447 20th May 2013 6:36pm
Did you sync them together at the same time? (essential)
Post #189456 20th May 2013 7:03pm
zetjester
Yes at the same time, the other keys get the response from the central locking, but the flip one wont.
thanks
Post #189480 20th May 2013 7:40pm
daveo
thanks
send me the link to the site you bought them from...i will have a look V8 facelift Range Rover Autobiography 22" wheels.
Post #189488 20th May 2013 8:50pm
zetjester
http://www.autokeytransponder.com/product_...em_id=1577
thanks daveo much appreciated Very Happy
Post #190570 25th May 2013 2:24pm
