Home > Maintenance & Mods (L322) > "Acme" Sleeper Ramps
Finally!
Beg: for some time of work to do some repairs on the FFRR
Borrow: 14" Stihl Chainsaw from work
Steal: of the month: 12 x 4ft Oak sleepers £25.
And I have created a flexible ramping solution for the FFRR and the other cars. Even though I can get under the car in off road height, this will make life a lot easier when doing under the car jobs, and assist with jacking. Good news, my 3 tonne axle stands just fit on the sleepers too.
The sleepers:
One Sleeper cut in two, a diagonal cut of 15inches (1ft from one end, 2ft from the other)
Four sleepers cut this way, providing everything needed
Also cut one sleeper into blocks for jacking, support.
Use a short piece, then a longer piece (normally a whole sleeper) then a longer piece on top
This gives a 9" lift
Could go higher to get 13.5" lift, if more height needed.
FFRR just crept up the ramp in high range when only trying one wheel at the front.
Aim to drill some holes and fit dowels to hold the pieces together. And will fit removeable stops at the end of the longer pieces. .
Post #177442 13th Mar 2013 10:39pm
thats how they built the pyramids Mr. Green
best ideas are always simple.... Thumbs Up ... - .- -.
Post #177443 13th Mar 2013 10:44pm
Cracking idea! Discovery 4 HSE
Post #177444 13th Mar 2013 10:47pm
PaulB
2017 Range Rover Autobiography SDV8 Loire Blue
Best part of the job is the lovely square cuts Thumbs Up
Post #177445 13th Mar 2013 10:47pm
daz62
United Kingdom 2003 Range Rover Vogue SE 4.4 V8 Oslo Blue
Clever thinking Joe Thumbs Up 03 4.4 V8 petrol / lpg. 1st of many hopefully. I love my Rangie
Post #177448 13th Mar 2013 10:50pm
They ain't so good close up, 14" blade on a 15" cut, and with a wibbly wobbly chainsaw, but the big (full) fat tyres soak up the difference.
Was planning to fix wooden battens on the slopes for grip but don't think they are necessary .
Post #177461 13th Mar 2013 11:19pm
Googsy
Do they come in different colours Thumbs Up Present :2008 TDV8 HSE
Gone Audi A5 2.7TDI
Gone Discovery 3 HSE
Gone Mercedes CLK
Gone Range Rover 2.5 DSE
Post #177467 13th Mar 2013 11:41pm
Why didn't you just learn to do this?
Post #177468 13th Mar 2013 11:47pm
he cant cos he's run out of wine bottles..... Mr. Green ... - .- -.
Post #177495 14th Mar 2013 9:05am
The Brains Trust
Australia 2003 Range Rover HSE Td6 Adriatic Blue
Love it! I'm going to steal that idea!
Cheers - Gav
Post #177513 14th Mar 2013 10:55am
Great idea Joe , Thumbs Up Thumbs Up
Or do it the lazy way … Whistle Laughing
http://www.fiammastore.com/Fiamma-Leveller...-Levellers ====================================
Post #177525 14th Mar 2013 11:24am
I've been using similar piles of wood nailed together for some years, the only thing I would suggest is that the "ramps" need to be wider for stability.
Twice the width at least, if not more.
This can be achieved by using cross pieces of timber as the base layer.
I find them much more stable than the steel versions and feel a lot more comfortable under the car when using them. Thumbs Up
Post #177528 14th Mar 2013 11:42am
GGDR
Great thread! DrRob I did notice those in the original post.
Four of those ideal for transmission fluid , keeps it level.
Plastic ones are only £32 on eBay, search "motorhome leveller"
With a bag!
. Cheers, Greg
Post #504179 6th Feb 2019 9:39pm
jagracer
United Kingdom 2011 Range Rover Vogue 4.4 V8 Zermatt Silver
I use my 3.5 ton plant trailer, I drive up the ramps after putting axle stands under the back of the trailer.
Post #624274 20th Feb 2022 9:02pm
