![]() | Home > General > What colour black do I have? |
If you have the speckle effect paint you have Santorini , if a straight gloss effect finish you have Java , or a dulled down effect it may be Sumatra black |
TTF Member Since: 06 Feb 2012 Location: Wiltshire Posts: 130 ![]() ![]() ![]() |
How old is the car, Santorini came in @2007, anything prior to that was Java?
Open bonnet and check plate inside it will have your paint code on it. I'm betting its Java black! Present :2008 TDV8 HSE
northernmonkeyjones Member Since: 24 Mar 2012 Location: derby Posts: 8750 ![]() ![]() ![]() |
Mines a 57 08my in java. Think santorini was later. There is nothing that can't be fixed with a hammer😜😜
RoryM Member Since: 03 Mar 2013 Location: Ireland Posts: 51 ![]() ![]() ![]() |
Thanks googsy. Thats exactly the answer I was looking for! |
stan Site Moderator Member Since: 13 Jul 2010 Location: a moderate moderated moderator moderating moderately in moderation Posts: 35644 ![]() ![]() |
and i'm sure you'd like to thank the other members that bothered to reply to your question... ... - .- -.
Cam-Tech-Craig Member Since: 04 Aug 2011 Location: Gloucestershire Posts: 16339 ![]() ![]() ![]() |
Santorini came in with the 2009 facelift...so simply, if you have the LED lights and the LCD dash then it'll be Santorini...
Pfazz Member Since: 07 Apr 2012 Location: Stalybridge, Cheshire. Posts: 507 ![]() ![]() |
Craig, I have a 61 plate and my sticker says Sumatra Black, just to add to the confusion! It has the LED lights and LCD dash so there must have been 3 different blacks at that time. Agueroooooooooo. 93-20
Yes, that's on a later MY again but he was asking for the date of the change from Java to Santorini... |
You're right Stan, a big thank you to all for your replies. This really is an excellent forum. I'll check the chassis # later to be certain. |
RRUK Site Supporter Member Since: 08 Jun 2007 Location: UK Posts: 6373 ![]() ![]() ![]() |
Santorini was later than 2007 so yours will be Java Black. Discovery 4 HSE
Java Jungle Member Since: 22 Mar 2010 Location: Monte-Carlo Posts: 420 ![]() ![]() ![]() |
![]() ![]() ![]() ![]() ![]() JJ |
..what would Henry Ford say about this thread? |
not a lot, he's dead.... ... - .- -.
