Home > Technical (L322) > air suspension question |
Joe90 Member Since: 29 Apr 2010 Location: Hampshire Posts: 6409 |
What was the fault code ?
10th Mar 2013 5:53pm |
Durham4416 Member Since: 10 Dec 2012 Location: Middlesbrough Posts: 248 |
When I got 'air suspension inactive' on the dash a couple of weeks ago my Indy said compressor, I bought some new wheels so jacked it up to change them, the car dropped to the floor on lowering the jack as yours did but once started it levelled itself back up, even if your compressor is knackered this will happen due to air still being in the system, on r I had the compressor replaced I can now use the dial on the dash to alter it normally |
10th Mar 2013 7:29pm |
Mr Tee Member Since: 13 Dec 2010 Location: Near Wackyjim Posts: 2655 |
You need an indie with the autologic kit, I had inactive on mine, was a height sensor, £110 all in! |
10th Mar 2013 7:39pm |
Cam-Tech-Craig Member Since: 03 Aug 2011 Location: Gloucestershire Posts: 16298 |
You need fault codes pal... |
11th Mar 2013 9:07am |
Yes I agree but I was just pointing out to not rule out a knackered compressor as mine lifted back up after dropping g to the floor and it turned out to be a compressor |
11th Mar 2013 2:00pm |
muffster Member Since: 03 Dec 2011 Location: Bradford Posts: 71 |
I don't know what the code was off the top of my head but it was plugged in at a good local indie who confirmed it was indeed the compressor.
11th Mar 2013 8:31pm |
I drove about 400 mile as I'd arranged to go to Scotland, couldn't obviously use the different height settings, just try park on level ground till its replaced |
11th Mar 2013 8:35pm |
Stoich Member Since: 21 Dec 2009 Location: Stornoway Posts: 36 |
Used mine for 2 years before I eventually got round to replacing compressor.
17th Mar 2013 11:43am |
daz62 Member Since: 27 Dec 2011 Location: Reading Posts: 201 |
Hi Muffster, I have replied in your own thread because it is going slightly off topic in the "clamshell" thread.
30th Mar 2013 8:41am |
