Home > Maintenance & Mods (L322) > 2002 - 2006 Facelift
comports
United Kingdom 2016 Range Rover Autobiography SDV8 Mariana Black
Hi Folks,
If anyone has done this - can they tell me if
1. once the wing tabs are cut off (to allow the lights to fit) is it absolutely necessary to "stick" the inner/outer wing together again.
2. If I don;t replace the bumper crash bar - is it easy to modify the old on so the fogs fit. I've got a price from Dan for a new one but trying to avoid paying out too much.
ps Dan - I'll pm you re the washer pump. (Thx)
Thanks
Ash Ash
2016 SDV8 AB
Post #176986 11th Mar 2013 1:16pm
i gather that you've read the wiki 'how to' Ash, is this not in there? ... - .- -.
Post #176987 11th Mar 2013 1:19pm
comports
I did Stan,
1 suggest body glue (so I just bought some metal epoxy) and another suggests making alluminium angles and rivets.
The second suggest you need to adjust the crash bar to accomodate the fogs but no mention of if it's easy. I gather its real steel as its a crash bar so not that easy to cut I would suspect.
Wondered if there was any comment from anyone that's already done the mod.
I've got most of the bits and trying to pluck up the courage to do it.! Razz Ash
2016 SDV8 AB
Post #176988 11th Mar 2013 1:24pm
Googsy
This should help
http://www.fullfatrr.com/forum/topic9699.html?highlight=facelift
Thumbs Up Present :2008 TDV8 HSE
Gone Audi A5 2.7TDI
Gone Discovery 3 HSE
Gone Mercedes CLK
Gone Range Rover 2.5 DSE
Post #176991 11th Mar 2013 1:37pm
someone that will know is Craig [cam-tech-craig]...ping him a pm Ash.. ... - .- -.
Post #176993 11th Mar 2013 1:40pm
comports
Will do - Thx Stan Ash
2016 SDV8 AB
Post #177013 11th Mar 2013 2:36pm
