Home > Maintenance & Mods (L322) > Intermittent Battery Charging/Alternator Problems |
Contraband Member Since: 08 Nov 2010 Location: FIFE Posts: 3697 |
I once had a fracture in a battery lead. I replaced batteries etc. I found it by chance, I was pulling at the lead to get at something else and I noticed a light flickered. By pulling the lead just a fraction I could switch all battery power off! Previously..
10th Mar 2013 8:10am |
nicedayforit Member Since: 11 Jun 2011 Location: Beside the Solway Posts: 3976 |
Have you checked the condition of the engine earth strap and it's bolted connections?
10th Mar 2013 10:20am |
RRUK Site Supporter Member Since: 08 Jun 2007 Location: UK Posts: 6369 |
I was also going to say that the earth connection could be loose. A dodgy cable is hard to diagnose but could be the case. Discovery 4 HSE
10th Mar 2013 11:19am |
dnbaker Member Since: 31 Dec 2012 Location: Tennessee Posts: 12 |
I did check the earth cables. In fact, I also replaced the battery earth cable and I even ran a new earth cable directly from the alternator housing to the earth connection on the strut tower. Unfortunately this made no difference. 2004 RR Westminster 4.4 V8
10th Mar 2013 11:51am |
Does your car have the hidden menu on the display that lets you see the battery voltage when you are driving?
10th Mar 2013 12:00pm |
I just ordered a voltmeter that plugs into the cigar lighter for this purpose. It will be interesting to see how the voltage behaves while driving. The real issue though is the fact that the alternator appears to have a mind of its own and will stop charging for periods (usually at the most inconvenient times). 2004 RR Westminster 4.4 V8
10th Mar 2013 12:16pm |
Don't forget that even though you replaced the alternator doesn't mean that the new one might not also be goosed. It can happen. Discovery 4 HSE
10th Mar 2013 12:21pm |
Does sound like a bad connection.
10th Mar 2013 12:34pm |
That's what I thought as well, so I replaced it a second time thinking maybe I got a bad one out of the box. I'm not keen on replacing it a third time - at least not until I understand why it's failing. There seems to be an underlying issue that so far I (and the local dealer) have been unable to identify. 2004 RR Westminster 4.4 V8
10th Mar 2013 12:36pm |
Forgot to mention that I also replaced the battery positive cable, thinking the pyrotechnic charge assembly might be faulty. I also checked the remaining connections at the firewall, rear of engine, etc. 2004 RR Westminster 4.4 V8
10th Mar 2013 12:46pm |
You seem to have done everything.
10th Mar 2013 12:54pm |
Based on some of your comments, I ran a separate wire directly from the alternator lug to the firewall lug. So far so good. Perhaps I do in fact have a break or short in the alternator cable. Time will tell. Thanks so much for all your comments & suggestions. 2004 RR Westminster 4.4 V8
10th Mar 2013 11:19pm |
