Home > General > Just bought a 4.4 2003
Scorchio
United Kingdom 2003 Range Rover Vogue 4.4 V8 Buckingham Blue
Hi there all, I'm a newbie so go easy on me ... although you do all seem a lot more polite than the guys at landyzone Wink
I was one of the first owners of a Black HSE TD6 back in 2002 that came out of Stratstone Derby, however the ex-wife got that in the divorce Crying or Very sad
Don't quite have the finances that I used to be just took the plunge and have won this on ebay -
http://cgi.ebay.co.uk/ws/eBayISAPI.dll?Vie...K:MEWAX:IT
Can i have your comments guys ? looks to be in good shape for it's age and a decent price ?
Post #17563 28th Apr 2010 9:02am
Jem0911
United Kingdom 2015 Range Rover Vogue SE SDV8 Corris Grey
Looks good to me,
Right colour and right interior.
Hope it goes well for you. 15MY SDV8 Vogue SE
Post #17566 28th Apr 2010 9:16am
Fox
Car and price looks OK to me.
I assume you did have a test drive already or before you hand over the money? (which the seller should understand)
Post #17567 28th Apr 2010 9:18am
Scorchio
Thanks guys - won't be handing anything over before test driving and pressing every button available. I am a little out of touch, can anyone give say 6 (or more ?) key points for known issues i should be looking out for ?
Post #17571 28th Apr 2010 9:38am
DMRR
South Africa 2009 Range Rover Westminster TDV8 Stornoway Grey
Rear wheel arches (check for rust)
Water in spare wheel well
Worn trim (!)
Excessive engine noise (squeaks, rattles FROM COLD)
Lumpy gearchanges
Ensure all heights work for suspension and it rises quickly and evenly (front to back) - it is NOT a common fault as the Ebay ad describes!
....and discoloured door handles Whistle Land Rover Addict
XXXXXXXXXXXXXXXXXXXXXXX
Previous
XXXXXXXXXXXXXXXX
2009 5.0V8SC Autobiography
2006 4.2V8SC Autobiography
2004 4.4V8 Vogue
Post #17573 28th Apr 2010 10:17am
dan_uk_1984
Pay specific attention to any knocks coming from the front end whilst hitting bumps. If you can feel them through the steering wheel then you will need to replace the lower ball joints in a few thou' miles. Not very expensive, 100-150 per side. Even cheaper if you do it yourself.
Also read up on the PCV Hoses (do a search) these cause no end of problems that can manifest themselves in all sorts of ways. Take some gloves with you, reach under the rear left hand side of the engine cover and grope around for some 1.5" diameter hoses, if they are all squishy like marshmallow then you should negotiate 150-300 off. These should then be replaced ASAP, doing so you should notice an improvement in MPG of 2-3mpg.
Dan
Post #17594 28th Apr 2010 2:16pm
Scorchio
Thank you all ... nobody local to Ely on Friday morning to give it the once over with me ?
In return you'll get ... the satisfaction of making sure I don't get ripped off !
Post #17606 28th Apr 2010 9:20pm
The link above works! The one on the PM wouldn't. nice looking car, those 19" alloys were one of my favourites, nice and chunky, easy to spot a 4.4 with those on.
rear privacy and side tubes look good on a dark car Whistle Discovery 4 HSE
Post #17609 28th Apr 2010 9:48pm
