Home > In Car Electronics (L322) > Driver Seat blows fuse |
nicedayforit Member Since: 11 Jun 2011 Location: Beside the Solway Posts: 3973 |
Which fuse is blowing? |
4th Mar 2013 5:41pm |
daveo Member Since: 21 Oct 2009 Location: london Posts: 2307 |
a fulty switch pack will blow fuses and it will stop the electric steering as well, i know this as when i removed my trim and unplugged the switch pack the steering stopped working, check to see if any of the loom has been cought. V8 facelift Range Rover Autobiography 22" wheels.
4th Mar 2013 5:49pm |
ksmith100 Member Since: 20 Apr 2012 Location: Stirling(ish) Posts: 77 |
Fuse 20 the 30A one, passenger seat is ok.
4th Mar 2013 5:57pm |
Unfortunately there are a considerable number of items protected by Fuse 20, all relating to the drivers seat functions. Anyone of these being faulty could cause the fuse to blow.
4th Mar 2013 6:35pm |
I noted the comments from Daveo but I have been under the seat and nothing is trapped or damaged, I wish it had been that simple I just replaced both catalytic converters last week due to some pr@t not welding them corecty!
4th Mar 2013 6:39pm |
ok you could do a few test yourself, start by unplugging all the plugs on the switch unit..then try to see if it stops the fuse blowing.. V8 facelift Range Rover Autobiography 22" wheels.
4th Mar 2013 7:35pm |
daveym Member Since: 21 Aug 2011 Location: place Posts: 62 |
I've spent the last couple of weekends sorting out the same fault!
4th Mar 2013 8:35pm |
Forget to mention that the wires behind the switch pack are suppose to be housed neatly, when I took mine off they were all over the place. The years of seat adjustment wouldn't have helped. |
4th Mar 2013 8:37pm |
Andy_l Member Since: 14 Jan 2012 Location: Gloucestershire Posts: 9 |
My old 2004 used to do exactly that. I never move the seat but the s/wheel would move every time as I turned the ignition on for a few days or weeks then the fuse would go. As the s/wheel was the only thing moving I assumed it was that mechanism maybe getting a bit sticky. I guess it could also be a shorting wire in the column too.
4th Mar 2013 10:57pm |
OK so guess what. I had the car in to get a brake disc shield replaced and asked the garage to have a look for anything obvious. They changed the fuse, again and now it all works again and has been since last week.
11th Mar 2013 2:12pm |
stan Site Moderator Member Since: 13 Jul 2010 Location: a moderate moderated moderator moderating moderately in moderation Posts: 35290 |
did the range come back nice and clean from the garage , i'm thinking a pressure washer would have caused your sensor problem if it had.. ... - .- -.
11th Mar 2013 2:20pm |
Yes it did (I had the same thoughts) I use a jet wash too but avoid the sensors. Not easy to prove it beyond doubt though. You are either at Le Mans or waiting for Le Mans
11th Mar 2013 2:56pm |
i would leave it for a while and let the sensor dry out [if it is that].. ... - .- -.
11th Mar 2013 3:22pm |
was the fuse prob down the the switch pack. V8 facelift Range Rover Autobiography 22" wheels.
11th Mar 2013 10:28pm |
