Home > Maintenance & Mods (L322) > Has anyone managed to free a broken locking wheel nut? |
alanm_3 Member Since: 19 Feb 2011 Location: my House, unless I’m not at home, in which case I’m somewhere else. Posts: 6729 |
I had the same problem. First pass was with an angle grinder, then my brother in law invested in a tool set which did the other without any damage to the wheel.
2nd Mar 2013 8:33pm |
Charmer Member Since: 28 Aug 2012 Location: Alton Posts: 156 |
I am in Alton, Hampshire.
2nd Mar 2013 8:35pm |
dave699 Member Since: 03 Apr 2012 Location: Redcar Posts: 457 |
Are you friendly with any RAC , AA mechanics? They usually have this tool set as part of their equipment.
2nd Mar 2013 8:52pm |
It came from these guys - http://www.dynomec.co.uk/locking-wheelnut-remover.html
Contraband Member Since: 08 Nov 2010 Location: FIFE Posts: 3697 |
My son stripped one on his BMW. I drilled a small hole through the head, as a pilot, then got a drill the same diameter as the threaded part. I drilled through the head until it got to the threads and the head fell off. Take the wheel off and the remaining part just unscrewed. Previously..
2nd Mar 2013 8:53pm |
Tried that method on the RR nut and also some form of reverse thread type thing, but nothing came close to budging it. I guess it all depends how tight it's been put on. Got - 2017 SDV8 Autobiography in Loire Blue
2nd Mar 2013 8:57pm |
Doesn't matter how tight it is if you drill through the head with a 13mm drill or whatever it was... The head just falls off. Previously..
2nd Mar 2013 9:01pm |
Indeed it does, but what was left on mine still wouldn't budge, hence the need for drastic action. Got - 2017 SDV8 Autobiography in Loire Blue
2nd Mar 2013 9:07pm |
Thanks for the replies.
2nd Mar 2013 9:40pm |
Googsy Member Since: 02 Jun 2011 Location: Where men are men and sheep are nervous. Posts: 2947 |
Once off replace with std nuts. Had 2 on my Disco do that . I was able to remove one at the front by removing all nuts on wheel and driving is a circle at slow speed. The weight of the car combined with the turning action caused the nut to crack and fall off. This method is apparently used by some mechanics to remove broken locknuts doesn't work all the time but worked for me. The wheel does not fall off as a result due to slow speed. The second nut I had to take it to a garage and they used a blow torch to remove. I hate locknuts and will never use them for that reason. Present :2008 TDV8 HSE
2nd Mar 2013 9:42pm |
Rest assured once this f ing thing is off they are all coming off and straight in the bin! |
2nd Mar 2013 9:45pm |
JustinP Member Since: 24 Oct 2010 Location: Cambridge Posts: 889 |
When a locking wheel nut jammed solid on my old SC, I asked my local LR main dealer to sort it when it next went in for a service. They initially said they would cover the cost of the labour if I paid for a new set of locking nuts (approx £32). But when I collected the car they apologised for damaging the wheel getting the nut off, and agreed to pay for the wheel to be repaired and also supplied the new locking nuts a locking key FOC.
2nd Mar 2013 9:48pm |
Does anyone think that using an impact wrench will have any success?
2nd Mar 2013 10:58pm |
Harvey123 Member Since: 24 Nov 2012 Location: london Posts: 95 |
I had this problem with the locking nut.
2nd Mar 2013 11:38pm |
