Home > In Car Electronics (L322) > Nav screen reboots on engine startup
Broadoak
South Africa 2007 Range Rover Vogue TDV8 Zambezi Silver
Hi. I am new here on the forums and to range rovers generally so please be gentle! I have a 2007 ffrr tdv8 vogue. My car reboots the nav screen when the engine is started. This is not a problem in itself, but it then fails to reconnect the bluetooth. I replaced the battery as I imagined that there was a voltage drop causing the screen to reboot to release power for the start. This however, has not fixed the problem. Anyone have any idea what's causing the screen reboot?
Post #174076 23rd Feb 2013 5:16pm
barracuda816
United Kingdom 2005 Range Rover Vogue SE Td6 Tonga Green
what battery have you put in it?
Mine did this too until i replaced the battery with the bosch s5 one. Also does it still do it if you charge the battery fully before starting?
Post #174088 23rd Feb 2013 6:31pm
Broadoak
Thanks for replying. It was a new LR battery from the dealer. They installed it from their store. I wondered whether it was fully charged but have not had a chance to charge it. Thought maybe just driving around would keep it near max charge.
Post #174093 23rd Feb 2013 6:51pm
barracuda816
I would, take the battery out (using the disconnect procedure in the wiki) charge it up overnight, and look at the CCA and A/H figures of the battery.
Put it back in and see if it still reboots.
Then post back the CCA and A/H figures.
Also how long are you average journeys? if you are only doing short runs it may not put a lot of charge back in the battery.
Post #174104 23rd Feb 2013 7:30pm
Broadoak
Thanks for the tip. Will trickle charge the battery and check. My trips are mostly short so that could be the problem. Time for a safari!
Post #174151 24th Feb 2013 7:49am
Nomad
United Kingdom 2012 Range Rover Autobiography 5.0 SC V8 Zermatt Silver
I have the same vehicle and my screen always goes back to the Land Rover Green Screen at start up before eventually coming back to life. I thought it was supposed to do that Confused I don't have the bluetooth problem however. That reconnects ok. I have a brand new Bosch S5 battery fully charged. 2012 5.0L S/C
Previous:
3.6 TDV8
4.4 HSE
P38 4.6 HSE
Classic 3.9
90 County
Series3 Lightweight
Post #174155 24th Feb 2013 8:43am
GraemeC
United Kingdom 2007 Range Rover Vogue SE TDV8 Zermatt Silver
I have a 2007 TDV8 Vogue SE - mine does exactly the same as Nomad, don't think this is a fault, just how they work... 2007 Zermatt Silver TDV8 Vogue SE - now sold but was a great car!
Post #174359 24th Feb 2013 9:23pm
Broadoak
Thanks Guys for your help. Seems like that is the way it's supposed to work then!
Post #174397 25th Feb 2013 5:17am
