Home > LPG > Which LPG System for a Supercharged?
Page 2 of 3 <123>
marcoos_1
Scotland 2006 Range Rover Supercharged 4.2 SC V8 Java Black
Hi Stan.....I know.....I've been deliberating over whether or not it's worth it. I know on my P38 that I sold recently it was a real saving, but this one is a bit more expensive so the return will no doubt be longer. I got the TD6 sold tonight, so the Supercharged is here to stay for a few years for sure.
The company that I've found so far for the conversion was Clyde Motor Engineers in Hillington. I've also been advised of a compny in Kilmarnock called McDowell. They suggested a system called GFI Pro? Has anyone heard of this? I'm going to do some googling....
Post #173840 22nd Feb 2013 12:05am
supershuttle
Stan got me thinking - thats a bad thing Sad
Assume VAT inclusive price £2,760
Assume 70p/litre saving
Assume 5lt to the gallon
Assume 15mpg
then
2760 divide by .7 - divide by 5 - times by 15 - gives about 12,000 miles
So that would be two years for me but probably only one or less for others.
This info is provided without any warranty or guarantee as to its accuracy as a public service, because I have nothing better to do particularly as I have a diesel Very Happy Geoff
Post #173846 22nd Feb 2013 8:01am
marcoos_1
I know...he got me thinking again too.....it is a close call for sure....and very much dependent on your mileage and duration of ownership.
I do think you need to factor in the residual value - I reckon the LPG kit becomes more attractive to buyers as they get older and lower in value. It might not be much - but if I was buying another one now I'd pay a bit more for a properely fitted LPG kit. It could also be removed and fitted to another vehicle.
I have to be honest..... I really miss the feeling of getting a 'deal' at the forecourt and spending half what everyone else is.....must be the Scotsman in me!
Anyway.....its 10.00 am and I'm sitting in my kitchen right now having a brew (the benefits of working from home!) and I'm watching Sky news....guess what.....
"Fuel prices set to Rocket to their highest ever".............
It's only ever going to go one way....and that's up!
Post #173870 22nd Feb 2013 11:24am
Ignore the milage, its the actual use, if your doing short trips which have a lower mpg anyway then the clawback is even quicker...
I spent £1900 on mine the coop and made the break even within 9months but was doing circa 25k PA then and fuel was costing me about 35p/l... I never saw more than 25mpg on petrol or LPG and it wasn't any worse on LPG but at the 9month period i had paid for the LPG install and started saving big time Very Happy
I found that once i had the engine started i could force the system onto LPG in very cold weather and anything about -1'c i force started on LPG anyway to increase the savings as the water was already flowing over the vapouriser and being warmed by a 5cylinder petrol engine and turbo it was fine.
The SC being a big JLR V8 should generate more than enough heat to keep 2 vaporisers from icing up from cold start. If it has an FBH even better Smile FFRR MY06 facelift With TDV8 Alloys Zeros/ATR's
Post #173871 22nd Feb 2013 11:39am
just for you Marcoos Smile
http://www.autogasyorkshire.co.uk/savings-calculator/
Have a play Smile FFRR MY06 facelift With TDV8 Alloys Zeros/ATR's
Post #173873 22nd Feb 2013 11:49am
Polux
2005 Range Rover Autobiography 4.4 V8 Monte Carlo Blue
u all over thinking this
Prins VSI (best on market) - £2200 inc vat
Autotech derby - <-- LPGA registered
Autotech derby - <-- Does 2/3 SC a week
Autotech derby - <--- setups and maintains the Bowler Wildcat engines
Nuff Said
Job Done
What are you waiting for.
Post #173893 22nd Feb 2013 1:14pm
steptoe
And don't forget the potential of fuel shortages, as happened a short while ago - when the forecourts have run out of petrol/diesel you're laughing as you fill up with LPG. Rolling with laughter
Post #173941 22nd Feb 2013 7:17pm
marcoos_1
Thanks guys. I'm convinced its worthwhile. I've changed around a few cars in the last couple of months and this ones a keeper.
I'll check out Auto tech Derby. My only reservation there is getting it back to them if something goes wrong.
Mark.
Post #174906 27th Feb 2013 11:01pm
Polux
did mine in 2008 never been wrong go every 18months for a £90 service
Post #175288 1st Mar 2013 8:33pm
Marc change you car avatar.... Whistle
Post #175291 1st Mar 2013 8:45pm
marcoos_1
Ooooops.........all done, cheers Gaz....
Post #175489 3rd Mar 2013 12:10am
dhallworth
Marcoos,
Only just seen this so hope you've not already had it done!
What ever you do, do not use Clyde Motor Engineers in Hillington.
They totally wrecked my Discovery 2 when it was in for an LPG conversion. They routed pipes badly, ground away my inlet manifold to make pipes fit instead of doing it properly etc. Guy told me he'd done loads of them before but mine was not right.
I took it back as it had no power on LPG so he ground more of the inlet manifold and rocker covers off to stop the pipes being squashed. Even after the conversion it still had a misfire on LPG at full power. They weren't even changing my inlet manifold gasket when they were taking it on and off so I ended up with air leaks etc etc. too.
In the end I sold the car and the guy who bought it took it to another LPG fitter down south, who commented that it was the worst LPG installation he'd ever seen.
I also spoke to another company in Glasgow who told me that Clyde Motor Engineers had a car converted by them and then proceeded to take the car apart when they got it back to find out how it had been converted. Apparently they broke it in the process of doing so and took it back to the company they'd had convert it and expected them to repair it under warranty.
Clyde Motor Engineers are a company that I wouldn't even trust to do an oil and filter change for me again, certainly not converting a car as nice as a Supercharged L322. I've also spoken to several people locally who have had cars converted by them and nobody has a good word to say about them. I also know of a P38 on LPG that they've ruined as well.
The owner, Jim, speaks a good game on the phone but I wouldn't trust him as far as I could throw him personally.
Post #180156 28th Mar 2013 10:04pm
Tallsaj
United Kingdom 2005 Range Rover Supercharged 4.2 SC V8 Zambezi Silver
Brc lpg on a sc prob
Hi I have recently had my sc converted To LPG Brc system it has 2 vaporizers but for some reason when i put my foot down hard it seems a bit hesitant as if something is holding it back. The place where I had the LPG fitted also can't figure it out prob it's the 1st one he has done and we have tried various software changes but with no success. Please would appreciate if some 1 could help me out on this one ;(
Post #205539 24th Aug 2013 10:28pm
marcoos_1
David,
That is good info to know. I haven't had my car done yet, because so far the suspension has gone down, the entertainment system has frozen and now I walk past it every day to get into my trusty old Landcruiser that has never let me down in 10yrs of ownership!
It would have been Clyde that I was going to use if going for someone up here......I'm glad I read this.
Down south it is then........
Post #210766 17th Sep 2013 8:18pm
n1cktdv8
£2.5k buys a lot of petrol ? Is this where I put the car details and a bit about myself ?........
Post #210768 17th Sep 2013 8:28pm
Page 2 of 3 <123>
