Home > Technical (L322) > Annoyingly slow fuel-filling |
Joe90 Member Since: 29 Apr 2010 Location: Hampshire Posts: 6405 |
Try holding nozzle at the 9 o'clock or upside down position.
21st Feb 2013 6:32pm |
dhallworth Member Since: 10 Oct 2011 Location: Glasgow Posts: 3031 |
Land Rover issued a service bulletin about this and the fix was to replace the filler pipe between the filler and the tank.
21st Feb 2013 6:55pm |
I knew I had a copy of it somewhere...
21st Feb 2013 7:26pm |
DaWalley Member Since: 24 Jan 2013 Location: Cheshire Posts: 42 |
Mine has this problem too - thought it was just me!
21st Feb 2013 8:27pm |
Lloyd Barnes Member Since: 21 Apr 2011 Location: Shrewsbury Posts: 181 |
As Joe says. Just put the nozzle in "upside down". Works a treat. Lloyd Barnes
21st Feb 2013 8:35pm |
stan Site Moderator Member Since: 13 Jul 2010 Location: a moderate moderated moderator moderating moderately in moderation Posts: 35114 |
http://www.fullfatrr.com/forum/topic9700.h...el+filling
21st Feb 2013 8:37pm |
I put the nozzle in upside down...and for fuelling the FFRR I... |
21st Feb 2013 10:44pm |
Andy_J Member Since: 14 Nov 2011 Location: Muir of Ord Posts: 479 |
Check you have not set the mis-fuel device. Look down the filler neck, if you can see a yellow plate blocking the filler neck you have set off the mis-fuel device and need to reset it. 56 TDV8 Vogue SE
22nd Feb 2013 12:03am |
Tuts Member Since: 24 May 2012 Location: Bishop’s Stortford, Herts Posts: 201 |
I was at a petrol station the other days and the pump was painfully slow , I asked the attendant he mentioned that when the temperature gets to extreme low temps (-1 or lower) the pumps begin to play up at the forecourt themselves. Could have been the same with you if it's really cold where you are? 2003 Vogue 4.4 V8 Java Black |
22nd Feb 2013 2:50am |
perroverde Member Since: 08 Sep 2012 Location: Lancashire Posts: 61 |
That'll be the problem! In a rush the other day I started to put petrol in instead of diesel and it (luckily) blew back and stopped me just in time. Thinking about it, it's since that incident that it's been troublesome, and yes there's a yellow thing visible in the neck. I'll investigate later is it an easy fix? Thanks guys. Oh and yes Andy it's freezing up north! |
22nd Feb 2013 8:40am |
Cam-Tech-Craig Member Since: 04 Aug 2011 Location: Gloucestershire Posts: 16230 |
There should be a reset tool in your boot sir... |
22nd Feb 2013 9:24am |
The pumps will often pump slower as the diesel is that bit thicker and they aren't designed well enough in the UK to cope with it
22nd Feb 2013 9:56am |
