Home > Technical (L322) > TD6 water pump change |
Rob2529 Member Since: 22 Nov 2010 Location: Wirral, uk Posts: 1470 |
There's a web based version of rave in the wiki. iPad friendly! [img]http://www.fuelly.com/driver/rob2529/range-rover[img/]
19th Feb 2013 10:08pm |
I think the part number is PEB000050G |
19th Feb 2013 10:14pm |
666tur Member Since: 15 Feb 2013 Location: Nottingham Posts: 108 |
Thanks
19th Feb 2013 10:22pm |
I would think the radiator would need to come out to allow access as it's rather tight in there |
19th Feb 2013 10:32pm |
Joe90 Member Since: 29 Apr 2010 Location: Hampshire Posts: 6408 |
To get at coolant pump looks like same procedure as thermostat, apart from the need to remove the ancillaries belt
20th Feb 2013 12:12am |
Thanks for the help.
20th Feb 2013 10:40am |
Done some more research. The plastic impeller had fallen off as I took the pump of, the metal is from the bearing. 2012 4.4TDV8 VSE
20th Feb 2013 10:47am |
If it were me I'd flush the system in both directions and leave it a good 10 minutes each way to do it. Also take the chance to flush your rad out and get any gunk from the bottom out.
20th Feb 2013 11:22am |
Thanks. I have been running a hose through every easily removable pipe to clear what I can. I intend to run it up to temp with water and drain down again before adding antifreeze.
20th Feb 2013 8:09pm |
The problem is you do need a skinny spanner to fit on the back "holding nut", and you are right, the Halfords fan spanner is just not long enough to get purchase. I bought a proper 32mm (monster) for the nut on the fan.
21st Feb 2013 1:18am |
Our advice then to others is get a decent 32mm spanner, I went into halfords originally to see if they had any. They said they only stock up to 19mm, then the lady said he'd check. She came back saying they had a 33mm one!!
21st Feb 2013 10:22pm |
Interesting, on mine, the "fan nut" was 32mm and oil filter cover 35mm ? .
22nd Feb 2013 8:18am |
