Home > Maintenance & Mods (L322) > Help!! 2010 headlights
Harvey123
United Kingdom 2006 Range Rover Autobiography Td6 Java Black
I have just connected up my 2010 headlights by using resistor boxes.. Jr auto electrics used to supply them on this forum.. Problem is the headlights work.. Main beam works, flash works but indicators and sidelights do not come on.. I have tested the connector to see if has power coming through and it does.. Both the indicator and side lights have power but just do not come on with headlights??
The model is a 2006 range rover
Please help
Cheers
Harvey Range Rover Autobiography Black Conversion
Post #172822 17th Feb 2013 1:28pm
Katash
England 2007 Range Rover Supercharged 4.2 SC V8 Zermatt Silver
LED polarity wrong maybe?
Post #172823 17th Feb 2013 1:30pm
Harvey123
Sorry whats that?? Range Rover Autobiography Black Conversion
Post #172825 17th Feb 2013 1:47pm
Katash
LED's have a requirement for correct polarity, unlike standard lamps .... If you have correct voltage at the terminals then maybe the LED's are reversed polarity for some reason.
Post #172826 17th Feb 2013 1:59pm
Harvey123
What would i need to do to change this?? Range Rover Autobiography Black Conversion
Post #172827 17th Feb 2013 2:01pm
Katash
Somebady with more experience of the conversion procedure would be better qualified to comment as I have no experience of this but you say the headlights work? ..... Are these LED or HID? ..... If the non LED lamps work but the LED ones do not then maybe you have your live ang ground round the wrong way somewhere. I'd wait to talk to someone who has this upgrade first before you do anything tho but I do know LED'S will only work if polarity is correct.
Sorry cant be anymore help.
Post #172837 17th Feb 2013 2:39pm
Harvey123
Yes mate i think ur right.. I think ive connected my earth to my live.. I thought the biggest brown wire on my loom was the earth.. I think thats wrong.. Who would i check which one is my earth wire as there are 3 brown wires???? Range Rover Autobiography Black Conversion
Post #172838 17th Feb 2013 2:50pm
Katash
I'm sure someone will be along soon to guide you
Post #172839 17th Feb 2013 2:59pm
Googsy
I would bet that JR will know send him a Pm. Thumbs Up Present :2008 TDV8 HSE
Gone Audi A5 2.7TDI
Gone Discovery 3 HSE
Gone Mercedes CLK
Gone Range Rover 2.5 DSE
Post #172841 17th Feb 2013 3:16pm
Harvey123
I will pm him..
So cheesed off with this... Range Rover Autobiography Black Conversion
Post #172861 17th Feb 2013 6:03pm
Jr-auto-electrics
England 2004 Range Rover Vogue Td6 Java Black
They were not supplied by me!!!
And if they were they would of had the correct instructions with them
And yes I do still produce these fix modules for the l322 RANGE ROVER 04 TD6
RANGE ROVER ULTIMATE EDITION 2012
UPGRADE.
MK 4 SATNAV
http://www.flickr.com/photos/jrautoelectrics/
Post #172867 17th Feb 2013 6:34pm
Googsy
Sorry misread Embarassed Thumbs Up Present :2008 TDV8 HSE
Gone Audi A5 2.7TDI
Gone Mercedes CLK
Post #172872 17th Feb 2013 6:53pm
Harvey123
Just recieved the diagrams from jr autos.. Going to give it a go.. Seems like the company i bought them off clearly didnt give me the full instructions
Thanks rob Range Rover Autobiography Black Conversion
Post #172902 17th Feb 2013 8:23pm
Jr-auto-electrics
Not a problem harvey any time,
Next time just come to me direct Thumbs Up RANGE ROVER 04 TD6
UPGRADE.
MK 4 SATNAV
Post #172907 17th Feb 2013 8:43pm
Googsy
That's what I will be doing when I'm doing mine Thumbs Up Present :2008 TDV8 HSE
Gone Audi A5 2.7TDI
Gone Mercedes CLK
Post #172910 17th Feb 2013 8:59pm
