As you all know it is sometimed easier and cheaper to pick up a set of 2010 spec rear lights NAS spec. these all come with side marker lights, which is not to everyones taste, and it just screams ive been converted. mine were annoying me , so here is the fix.
Measuring from the top edge of the light on the back measure down 130mm, and then in 35mm. drill a 6mm hole and this takes you into the back of the circuit board where you find the bulb that is the marker light, break the connection going to the bulb. Problem sorted.and no effects from this
i drilled a 6mm hole as i had this size of grommet lying about, then ran a smear of sealer round edge of it
