Home > Technical (L322) > Side indicator not working
Ibartsimp
France 2008 Range Rover Vogue TDV8 Buckingham Blue
While my car is a the dealer for the drain problem, I wanted your opinion on something.
In the process of my problems, I had to feed the car in electricty through the indicator as described here:
http://www.rangerovers.net/forum/6-range-r...ttery.html
So I cut the wire and used an earth point, then rewired the cable. Since then the indicator doesn't work.
I've of course swapped bulbs to check it wasn't the bulb, I've of course checkd the cut wires made good contact (maybe someting special to do here?)
One suspicion would be that I've pulled too hard on the cable and unplugges something beneath the panel?
Any ideas?
Thanks 2008 TDV8 VOGUE - Buckingham Blue on Sand
Post #172602 16th Feb 2013 7:25am
Shocked
Post #172619 16th Feb 2013 9:32am
that link refers to 'unlocking with a dead battery'.... ... - .- -.
Post #172649 16th Feb 2013 11:29am
It also refers to unlocking through the side markers (American vehicle lamps fitted to side of vehicle) so if you have connected power through the side indicator you could have blown something
Post #172661 16th Feb 2013 11:42am
Ibartsimp
It was my understanding that marker was the us term for indicator...
My pb was described here http://www.fullfatrr.com/forum/topic15916.html 2008 TDV8 VOGUE - Buckingham Blue on Sand
Post #172671 16th Feb 2013 12:21pm
