![]() | Home > In Car Electronics (L322) > MOST (again) |
TugRR Member Since: 11 Jan 2011 Location: Bakewell Posts: 1200 ![]() ![]() |
Land Rover sell such a cover - I put one in mine. Can't remember the exact name or part no., but Dan at Duckworth's will know -
It is just a simple cover made from see through plastic. Have a look at some photos and you can make it yourself or spend a few quid getting it from Dan. After drying out all connectors, have you used some connector cleaner as well, it may help in getting any residual corrosion out as well. MY 2010 5.0 SC Galway green and sand interior!!
bazwd Member Since: 14 Feb 2013 Location: Bristol Posts: 26 ![]() ![]() ![]() |
That's great. Many thanks for the advice about the shield and the protection, and for the prompt response. |
Cam-Tech-Craig Member Since: 04 Aug 2011 Location: Gloucestershire Posts: 16339 ![]() ![]() ![]() |
The cover is called a water shedder |
stan Site Moderator Member Since: 13 Jul 2010 Location: a moderate moderated moderator moderating moderately in moderation Posts: 35646 ![]() ![]() |
search 'water shedder' and there are a number of threads re this... ... - .- -.
Thank you once again for the excellent advice which I will duly follow.
