![]() | Home > Camping, Caravanning and Holidays > Euro tunnel with FF plus 8mtr caravan and dogs. |
northernmonkeyjones Member Since: 24 Mar 2012 Location: derby Posts: 8747 ![]() ![]() ![]() |
You are pretty much straight on the autoroutes the other side not a lot of chances to get lost. Just make sure you get on the right one! |
Alistair Member Since: 11 Feb 2011 Location: Peterborough / Bordeaux / Andorra Posts: 7998 ![]() ![]() ![]() |
Not taken a caravan, but have taken trailers and boats (on trailers) - its very easy.
cleughy Member Since: 08 Mar 2012 Location: West Kirby Posts: 361 ![]() ![]() ![]() |
dont you need a vets certificate for dogs to come back in the country? |
Andy3681 Member Since: 13 Jan 2012 Location: Newcastle under lyme/ Le Dorat Haute Vienne Posts: 912 ![]() ![]() ![]() |
With a long unit you need to swing wide to get on the train to get nice and straight behore you enter the carriage but like the other posts you will be in with the coaches.
ksmith100 Member Since: 20 Apr 2012 Location: Stirling(ish) Posts: 77 ![]() ![]() ![]() |
Tunnel is the way to go, much easier and quicker than the ferry |
Mapmuppet Member Since: 03 Sep 2008 Location: Guildford Posts: 153 ![]() ![]() |
Watch out for the height restriction bar at the Eurotunnel terminal UK side. Last trip a tad costly as the max vehicle height bar set at 1850mm 'removed' the GPS fin....... Having been told by Eurotunnel reservations that the FFRR would be within the 1850mm limit ( Offical RR Figures 1820mm ).. Was Offered �20 compensation in return... THANKS ! 2005 Audi A8 W12
stan Site Moderator Member Since: 13 Jul 2010 Location: a moderate moderated moderator moderating moderately in moderation Posts: 35610 ![]() ![]() |
you should always go in the coach/caravan carriages, less toilets , more width/height and normally quicker on/off. ... - .- -.
Andy Member Since: 24 Feb 2009 Location: Shropshire Posts: 2944 ![]() ![]() ![]() |
Just watched a YouTube vid showing a caravan going into the train- it's probably the camera angle but it looks very tight getting through the entrance! |
It's fairly wide, so as long as your competent, it's straightforward - you're in the same carriage as the coaches.
roger 47 Member Since: 24 Aug 2012 Location: Exmoor Somerset Posts: 80 ![]() ![]() ![]() |
Thanks to everyone for the useful information. I've certainly pick up some good tips. |
1. This from DEFRA site:
Driver must have been a moron, it's about as well signposted as it can be and you usually just follow the line of cars in front anyway. The opening is most of the length of a carriage, so you just swing in. It's exactly the same for coaches, they load through the same door into the same carriage. Of you're even half competent it's nothing to worry about. |
To give you a sense of the size of the carriage, this was me last Friday -
Just thought - check on LPG - not having a caravan, it doesn't affect me, but I think there's a complete ban. |
