![]() | Home > Technical (L322) > Won't jump start |
JAYBOY Member Since: 17 Oct 2012 Location: South Wales Posts: 2204 ![]() ![]() ![]() |
Not enough power.
baldylocks Member Since: 05 Apr 2010 Location: Gods Own County Posts: 42 ![]() ![]() ![]() |
Cheers, I did wonder but when I checked the Spec for the Clarke it reckoned it would start up to 6L petrol or 4L diesel. I guess the TD6 needs quite a bit of power to start it then? |
stan Site Moderator Member Since: 13 Jul 2010 Location: a moderate moderated moderator moderating moderately in moderation Posts: 35648 ![]() ![]() |
try and leave the charger connected for about ten minutes before you crank the range... ... - .- -.
comports Member Since: 20 Dec 2010 Location: Colchester Posts: 1754 ![]() ![]() ![]() |
How are you connecting the leads. I was told that if you connect to the battery terminals of a completely flat battery, the flat will be consuming some of the power. the correct way is pos to pos and neg to engine block therefore not going through the dead battery. not sure how true it is but worth a try. Ash
Get a car upto it that's running and connect it up and give it 5-10mins and that will get it running.
Richcl Member Since: 23 Sep 2010 Location: Tewkesbury, Glos Posts: 1011 ![]() ![]() ![]() |
I had the same with mine last night (TD6) battery pack couldn't do it, even tried jumping of a slave battery. In the end I put battery charger on it for an hour. |
PaulB Member Since: 17 Jul 2011 Location: Hampton Posts: 877 ![]() ![]() |
The Clarke pack has started mine a few times from completely flat...no dash lights zilch.
northernmonkeyjones Member Since: 24 Mar 2012 Location: derby Posts: 8750 ![]() ![]() ![]() |
I managed to jump mine from a cheap booster whilst in the queue for the iow ferry.(damnation to the tv and coolbox) just did it.
Alistair Member Since: 11 Feb 2011 Location: Peterborough / Bordeaux / Andorra Posts: 8001 ![]() ![]() ![]() |
Agree - its more than likely a poor connection.
Havank Member Since: 05 Apr 2007 Location: Woking - Surrey Posts: 193 ![]() ![]() ![]() |
Clever ![]() |
Thanks guys, an hours charging this morning and it started with the booster. Funnily enough I fitted Anderson connectors to my Defender so I know I'm getting a good connection there but haven't bothered on the FF, I'd need some new Anderson to Anderson leads! |
^^^ Havank,
RRUK Site Supporter Member Since: 08 Jun 2007 Location: UK Posts: 6373 ![]() ![]() ![]() |
Agreed. I have the Clarke Jumpstart 4000, since I bought it it's mainly been used to jump start the tractor mower! However the Defender sat for a month and wouldn't turn over, so I attached the JS4000 and left it for about ten mins, then tried cranking it. It just needed some charge getting into the battery. As an aside I once tried using my JS4000 on my dad's TD6 and it wouldn't work - I had just bought it and was very proud to get it out and show him how it's done, felt a right berk at the time but it turned out to be a seized starter motor in his case so was never going to work. Discovery 4 HSE 1998 110 TUM HS FFR Hard Top XD WOLF 1982 Series 3 Hard Top *Gone:L462 D5 HSE LUX, L663 Defender 110 HSE, Discovery 3 HSE, 2014MY Range Rover Sport 5.0 Supercharged AB Dynamic; L405 Exec Vogue SE 4.4, 5.0 Supercharged Autobiography, Defender TDCi XS CSW, Defender TD5 HT, Vogue SE TDV8, Vogue TD6, RRSport SC 4.2V8, Classic 3.9 Vogue Auto, Land Rover Series 3 SWB |
I think the TD6 is just a hard engine to crank compared to the V engines |
